20 Most Recent
Campbell Hausfeld VT6290 2.0 HP 20 Gallon Oil-Lube Wheeled Horizontal Air Compressor Questions & Answers
Air Compressor trips breaker under load. If I
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
12/11/2013 3:29:28 AM •
Campbell...
Answered
on Dec 11, 2013
Campbell Hausfeld air gun has air coming from the nose tip and no nails
If air is coming out from the nose tip but the nailer is not firing any nails, it could indicate a problem with the driver blade or piston assembly. Check if the driver blade moves freely and is not damaged. Make sure the piston assembly is properly aligned and lubricated. Also, check the nail magazine to ensure that it is properly loaded and the nails are the correct size for the nailer. If the problem persists, it may be necessary to take the nailer to a professional for repair.
2/14/2023 2:59:32 AM •
Campbell...
Answered
on Feb 14, 2023
Need to know start cap specs for c1071080vmsa campbell air compressor
Kranson 3 Nov 03, 2022
I'm late to the party, BUT...
There's 2 ea of both start and run capacitors in this compressor...
Start: PN- 351052-53, 815-970 MFD, 165VAC
Run: PN- 175863-30, 30MFD, 370VAC
The section ^^ UP THERE ^^ is for asking the OP further information before committing to an answer down here. The question is now marked SOLVED and will show in Search. Thanks
11/3/2022 5:10:21 PM •
Campbell...
Answered
on Nov 03, 2022
Campbell hausfeld wont build pressure
The most probable are
Leak in air lines, bad valves, bad piston rings or o rings., bad check valve on tank, leaking unloader valve. Tou can google your model number and there will be more info.
10/30/2021 3:21:28 PM •
Campbell...
Answered
on Oct 30, 2021
Why does my campbell hausfeld 80 gallon 2 phase air compressor start to bog down at 90 psi
There is many reason for this simptome ,
could be running capacitor ,, Pressure switch dirty or it going bad,, Or ,If you meen lick choking and conteniu going could be also your check valve ,,,
If you can post a video I will help you better ,
I need to hear what it doing ,
9/8/2019 9:33:07 AM •
Campbell...
Answered
on Sep 08, 2019
Campbell Hausfeld workhorse 3.5 stops after it gets hot and only hums when you try to restart. After sometime left turned off will restart but does the same thing
This fault indicates that there is too much back pressure on the pump causing the motor to strain. There is a check valve located at the tank that prevents pressurized air from returning to the compressor. Here is how to test for leaking check valve. With no air in the tank, run the compressor till you reach about 40psi and shut off the unit. Listen or air leaking out of the air filter or the pressure switch. Leaking air indicates bad check valve. If no leak, allow the compressor to reach fail condition, then unplug the compressor and immediately let out all the air and see if the compressor restarts easily. If the compressor will not restart with no air in the tank then may have failing capacitor (s). Easy to replace. ;Good luck with your repair.
9/5/2018 2:26:28 PM •
Campbell...
Answered
on Sep 05, 2018
