20 Most Recent
Acer Aspire 5552 5552g 5553 5553g 5560 5560g 5625 Clear Keyboard Skin Cover Questions & Answers
The wifi switch wont move to on
Hello Kim
try this
1) Press firm and move to on position. check
2) bad on off bottom (need to change)
3) try to see if you have on keyboard a wifi option to on the signal * on some models only of course.
4) spray the bottom to clean dirt, or clean the botton with alcohol 70% with QTIP
Carl
Mic is not working
make sure it is listed in the control panel audio screen as an input device and that it is not muted in the mixer
My acer aspire 5553G has no sound
ensure that sound is not muted. if it is not go into device manager and check that the sound and video drivers are properly installed
Acer aspire 5552g format
to reinstall from recovery partition see below link, it it is of no use to you please add more detail and resubmit your query
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Acer aspire 5552g wont start
see below, if that is no good add more detail please and resubmit
Cannot locate built in microphone
Have you checked in volume control that your mike is listed and is not muted. sorry, that is volume control/mixer.
You should also enter the sounds/ audio control section of your machine and ensure that microphone is there and is listed and ticked as an input device.
Laptop wont power on
Hi yes the laptop will still power on and at least beep at you or light up the LEDs and start the fans, you will get no display with out the ram installed, but you will get a basic power on so listen for those fans,if you install the ram you should get a a display on the screen with the branding logo and boot information but without the hard drive it will have no operating system
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
