20 Most Recent
SMC EZ Connect Modem Questions & Answers
Just had a new router put in by Time Warner Cable
I would need a few more details to really get to the heart of this but the first thing I would do is connect this Dell to the router with an actual cable, if only temporarily. See if there are still issues when directly connected. Depending on answer to that you would know if the wireless is some how responsible or if there is some other cause. If there are no issues with a direct cable I would say it is the wireless card or signal. You could a try different wireless hardware on the dell or switch channels on the wifi router to see if that helps. I can't think of a reason why four computers on the same router would respond differently to a specific site.
Hi, i m using a smcd3gn-res wirelles modem and i
g_ta_s
There is 2 ways you can lock down your router. If you are going to allow friends and family to access your router then you can setup a WEP key. This will be a pass phase that they would put in to get access. The other way is to use the MAC filter. Using the MAC filter you can put in the MAC address of the wireless device that you want to allow to access you router and only those devices will be able to access the network. Note you have to manually add the MAC addresses to the filter list to get them to work.
Let me know if you are having trouble getting these setup and I will put together a walk through for you.
Issken
My cable light on my
Call the cable company to come out for a service call... it sounds like signal issues... could be as simple as a bad splitter or connector.
MBP8,1 late 2011 new battery not working
You realize people reading this have no idea what this mumbo-jumbo means. Brett has no idea and he is the master of all masters in lateral thinking!
'make model (what it is)', plus a detailed description of the issue!
Wat is the smc networks use for
SMC Networks serves up networking equipment, with or without wires. The company makes wireless local area network (LAN) devices designed for use in homes and businesses.
How to solve USB device not recognized ?
different USB port. There are usually 3 or 4 of them. If you can, format the USB drive (if you have nothing on it or already have copies of what is on it). It will take 10 seconds, but will wipe all data. It should be recognized then.
When trying to use the
look for a windows xp driver file on the included program compact disc that may need to be installed before you use the included program.
