20 Most Recent MSI Wind Top AE2020-49SUS 20 inch All-in-one Multi-Touch Screen Desktop PC (Black) (AE202049SUSBM4503G32Hewlett Packard) Questions & Answers
Connect my msi all in one computer to tv with vga/svga video cable
Assuming your TV is HDMI input only you'll need a converter. Once you've installed the converter it will be very easy just plug them together set your TV's input to what ever HDMI port you've plugged in. on your PC desktop rightclick go to properties and enable the second display. http://www.amazon.com/s/?ie=UTF8&keywords=vga+hdmi+converter&tag=mh0b-20&index=aps&hvadid=3482721557&ref=pd_sl_44liqj4bpp_ee
4/18/2014 8:00:35 PM • MSI Wind Top... • Answered on Apr 18, 2014
0answers
How to fix the touch
Have you rebooted the machine? Locate the service in SERVICES (open the Start Menu, All Programs, Administrative Tools, Services) , and restart the processes. You can search MSI support: http://www.msi.com/product/mb/Wind-Top-AE2020.html OR: http://www.msi.com/service/troubleshooting/
3/28/2013 5:40:33 PM • MSI Wind Top... • Answered on Mar 28, 2013
Cleaning cooler of my PC
Are you able to open unit up? if so, get some canned air and blow heat sink off and try to do so that dust leaves unit and not just moved around
1/29/2013 6:06:27 PM • MSI Wind Top... • Answered on Jan 29, 2013
2answers
Why Windows 7 Pro Prompt me to backup file encryption certificate and key
Most likely thinks your version is a clone. I kept having this happen to me with a new computer I bought with Vista on it. After a week I got fed up of it and demanded my money back at the store where I bought it.
3/8/2016 5:17:32 AM • MSI Top... • Answered on Mar 08, 2016
START UP PROBLEM
there must be a hardware fault it could be that your system won't support your hardware configuration or it could be the heating problem... you better take your PC to an computer engineer
9/6/2014 5:36:18 PM • MSI Top... • Answered on Sep 06, 2014
Stops loading at 50 percent at double u casino
Open run by pressing window and 'r' key together and type %tenp% then hit enter, delete everything after selecting all, this is all temp data, clear all your browser history, AND TRY again please.
5/13/2014 2:04:28 PM • MSI Top... • Answered on May 13, 2014
0answers
Not loading
Be the first to answer 2/25/2014 4:33:34 AM • MSI Top... • Posted on Feb 25, 2014Be the first to answer
Cannot load to double u casino stops at halfway
Try installing the game in safe mode.
12/9/2013 6:38:16 PM • MSI Top... • Answered on Dec 09, 2013
0answers
0answers
Msi desktop bluescreen problem
bluescreen can be caused by a number of things
a bad driver loose or faulty lead or not having enough ram
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumpsmake sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal pasteif you dont want to install more ram uninstall some unnecessary programs a bad or faulty motherboard lead or its connection if its a flat 40 pin ide it will be the first to failmake sure all leads have a dust free secure connections
hope it helps
5/19/2012 4:50:22 AM • MSI Top... • Answered on May 19, 2012
2answers
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver: 1. Find your graphics card model. Note down the model number. 2. Go to MSI's website. 3. Look for the support or downloads tab and click on it. 4. Use the search or menu options to find drivers for your specific graphics card model. 5. Download the driver package. 6. Run the installer file once the download is complete.
3/26/2024 10:36:50 PM • MSI Computers &... • Answered on Mar 26, 2024
Screen does not fit after adjusting the screen resolution msi N082 i tried updating the VGA driver online but it keeps telling me that driver is up to date
If adjusting the screen resolution didn't resolve the issue and you've already updated the VGA driver, try manually adjusting the display settings through your computer's control panel or display settings menu. Look for options like overscan or scaling to ensure the screen fits properly. If the issue persists, it could be a hardware problem or compatibility issue with your monitor. Consider reaching out to MSI support for further assistance.
3/26/2024 12:50:33 PM • MSI Computers &... • Answered on Mar 26, 2024
How do i connect my fire stick thru bluetooth on my MSI windows 11 laptop??
To connect your Amazon Fire Stick to your MSI Windows 11 laptop via Bluetooth, you will need to follow these steps:
  1. On your Fire Stick, go to Settings > Display & Sounds > Enable Bluetooth.
  2. On your MSI Windows 11 laptop, go to the Windows Settings > Devices > Bluetooth & other devices.
  3. Turn on Bluetooth on your laptop and make sure that it is in pairing mode.
  4. On your Fire Stick, select your laptop from the list of available devices.
  5. On your laptop, click "Pair" when prompted to complete the pairing process.
  6. Once connected, you should be able to stream content from your Fire Stick to your laptop.
1/20/2023 11:59:27 PM • MSI Computers &... • Answered on Jan 20, 2023
Wanting to connect an older AV received to my Win 10 PC via optical input. Should I use MB or Graphics output?
You should use the audio output on your computer that is labeled as "optical" or "S/PDIF" (Sony/Philips Digital Interface Format) to connect to the optical input on your AV receiver. This will typically be labeled as the "digital audio out" or "digital output" on your computer. The "graphics output" is used for video, not audio.
1/12/2023 2:39:40 PM • MSI Computers &... • Answered on Jan 12, 2023
How can i enter the bios on my pc.
Proper training and equipment are needed to modify the (Basic Input Output System ) BIOS on a PC. You could turn your PC into a paper weight. The game has been criticized for its anti-cheat software, Vanguard, as it was revealed to run on akerneldriver, which allows access to the computer system.[56]OSNewsexpressed concern that Riot Games and its owner, Chinese technology conglomerateTencent, could spy on players and that the kernel driver could be potentially exploited by third parties.[56]However, Riot Games stated that the driver does not send any information back to them, and launched abug bounty programto offer rewards for reports that demonstrate vulnerabilities with the software.[57][58]The bounty will reward white hat hackers between $25,000 to $100,000 for reports on its vulnerabilities, with the pay being based off the severity of the exploit.[59]Gameplay bugs do not qualify for this bounty.[59] Valorantwill not run onWindows 11if the system does not have aTrusted Platform Module(TPM) 2.0 compliantcryptoprocessorandUEFI secure bootenabled, as mandated by Microsoft's minimum system requirements for the operating system.[60]
11/20/2022 7:19:17 PM • MSI Computers &... • Answered on Nov 20, 2022
Replacing an msi laptop screen
no PC told at all MSI is maker only but yes they all unplug on laptops(is it) they are held on by tricky ways and if forced you break mobo or display there are the easy ones push on pull off the the wedge locked, , unlocked first. and last the hinge lock FFC cable ends learn not to force them, look first for locks, 2/3rs of them are locked.
8/22/2022 8:33:42 PM • MSI Computers &... • Answered on Aug 22, 2022
MSI Wind Top AE2020-49SUS 20 inch All-in-one Multi-Touch Screen Desktop PC (Black) (AE202049SUSBM4503G32Hewlett Packard) Logo
6 questions posted
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Top MSI
  • Top MSI
Most Popular Question
connect msi all in one computer tv vga
  • Computers & Internet
