bluescreen can be caused by a number of things
a bad driver loose or faulty lead or not having enough ram
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumpsmake sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal pasteif you dont want to install more ram uninstall some unnecessary programs a bad or faulty motherboard lead or its connection if its a flat 40 pin ide it will be the first to failmake sure all leads have a dust free secure connections
hope it helps
2 questions posted
3 Questions
5 Questions
