20 Most Recent Hitachi 43FDX01B TV Questions & Answers
I have a Hitachi Ultra Scan HD TV model #43FDX01B - Green line
Hitachi Projection TV Repair Kit for one or more of the following symptoms This might not be your model but you should contact them to see if the have the parts I know they list the manual
2/26/2018 5:51:30 PM • Hitachi 43FDX01B... • Answered on Feb 26, 2018
How do I get my hitachi tv past the lock screen. I can't enter the code for my tv because it won't go to that screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Unlock procedure to many popular brand TVs are given.
8/11/2014 7:34:48 AM • Hitachi 43FDX01B... • Answered on Aug 11, 2014
Hitachi L26DPo4u now only works in black and white
check your color setting by going display if problem not there then you need to change your display tune which built in your tv internal side its a small machine like a box. just change it it will work fine.below 1 link add if want then you can help by donate and you can spread it with your friends circle for help me Please Help Me To Get Out Of Debt wish you will help
7/13/2014 7:03:57 AM • Hitachi 43FDX01B... • Answered on Jul 13, 2014
Key for photo movietheater
Download it from - http://crackstorage.com/get_uploaded_file.php
6/8/2014 7:02:34 AM • Hitachi 43FDX01B... • Answered on Jun 08, 2014
Red and green flashing on tv
internal error may be light wire got lose connection
5/30/2014 7:46:40 PM • Hitachi 43FDX01B... • Answered on May 30, 2014
Tv will not turn on have a red and green flashing light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
5/30/2014 4:12:21 PM • Hitachi 43FDX01B... • Answered on May 30, 2014
I need service mode code for hitachi crt tv
It is too much to type in here, about how to enter, adjust and exit service mode. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
10/25/2013 1:45:45 PM • Hitachi 43FDX01B... • Answered on Oct 25, 2013
manual
Tv went out after lightning storm. all I get is red light on the front of tv.
Its main digital board should be checked. Contact any service technician.
7/2/2013 7:45:42 AM • Hitachi 43FDX01B... • Answered on Jul 02, 2013
Reset tv to factory setting
To reset to factory settings, you have to enter its service mode option. If you wish to know, how to enter and exit service mode, and make adjustment with it, check this link. It has detail about this. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option.
6/25/2013 10:13:52 AM • Hitachi 43FDX01B... • Answered on Jun 25, 2013
3answers
Looking to buy a new IC kit for my 43FDX01B, but
first, I would not buy a "kit"; prices on these range from 40 to 80 dollars and most of the parts are not going to be needed.
See attached photo of convergence board in a set like yours.
You can look at the two chips in your set: either they are STK-392-110 OR -150--BOTH ARE THE SAME BUT THE 150 LASTS LONGER.
A FEW VERSIONS WILL USE STK-392-120---IT IS NOT INTERCHANGEABLE WITH THE 110 OR 150 CHIP.
In either case you can buy on EBAY (A seller I use) a pair of the chips for about 12 dollars.
About the only other thing that goes bad is there may be damaged resistors around one of the chips--usually just one but they are easy to spot and or test (see photos)
No matter how you add it up you can buy the parts you need for under 25 dollars including shipping.
If the photos and information I have provided helped you, rate this solution as very helpful as I do this here for free.
SD TECH
11/26/2012 6:58:35 AM • Hitachi 43FDX01B... • Answered on Nov 26, 2012
Hitachi 46f500 resistors
Google this----the burnt one will look bigger----most are actually 1/2 watt and none that burn are over 1 watt. If 46 one of the two chips for convergence got it.
11/4/2012 4:38:37 PM • Hitachi 43FDX01B... • Answered on Nov 04, 2012
How do you connect a Directv box (satellite box) to this tv? Which outets do you use on the back of tv? When you go in the menu of choices, you are given only antenna or Cable 1 or Cable 2. Which one
Send your email address to me by Fixya, and get back a manual which describes all detail by return mail. Check this link too. Sometimes it might help you.
10/2/2012 9:09:26 PM • Hitachi 43FDX01B... • Answered on Oct 02, 2012
Manual for Hitachi CLU- 575TSI
Click here to download it.
8/20/2012 3:44:35 PM • Hitachi 43FDX01B... • Answered on Aug 20, 2012
Hitachi 43FDX01B TV Logo
288 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
tv went out after lightning storm all
  • Televison & Video
