20 Most Recent
Peavey SP4 2-Way PA Cabinet (2000 Watts, 2x15 in.) Questions & Answers
Sp4 blown fuse
It's not a fuse, it is a lamp and I suggest ordering replacements directly from Peavey.
Blown fuse
It's not a fuse it is a lamp... to insure that you have the proper replacement, I suggest reordering from Peavey.
Crossover blow drivers.How can i get the part for
Hello iwelch1194:
The thing you are describing is called a choke or a ferrite crossover coil.
This site might have what your looking for:
"CLICK HERE"That is there ferrite page. If you need something a little different just search their site. You will also need to know the
COIL
VALUE and
wire size which should be labeled on your old coil in order to replace it with something compatible.
Coils are rated in millihenrys (mH).If this helped just click the thumbs up.
Your FixYa team member, Peter N.
Need screws and press in tread grommets (15) star
These should be available from Peavey directly. Call the service number and ask for the parts dept. Describe exact screws you need and they will provide you with the part numbers and costs. They can also send you what you need. I have dealt with them in the past and they were very helpful.
Dan
From their website:
To order replacement parts, please call us at 877-732-8391 (toll free in the US) or 601-483-5365. The Parts Department extension is 1386. Our business hours are 8 a.m. - 5 p.m. Central Time, Monday-Friday. Hold times may be long during peak hours. If you have to wait on hold, feel free to leave a name and number and one of our Parts Sales Coordinators will contact you as soon as possible. Payment can be made via credit card, or we can ship COD to a place of business only.
For parts pricing and availability inquiries only, email the Parts Department at
[email protected]
I have a new peavey
This is based on MOST cabinets like this: First look for any small screws which are usually through the grille near the top and bottom that retain the grille. When those are removed, one has to pry the grille out of the grooves at the side by dishing the grill outward at the center so edges come inward. There often is a "U" shaped rubber strip along the edges that will need to be put back on before grille is dished and put back.
Note that SOME speakers have a fuse or a polyfuse to protect them from excessive current. If yours do not, consider puttin in polyfuses to protect them. They are available from Digikey.com.
Calculate the hold current based on the pwer rating and impedance. Take the square root of the rated power of the HF divided by the impedance and choose aa polyfuse that will hold that current and one that will standoff the peak voltage of your amps. Calculate that voltage as the square root of the max power of your amp divided by the LOWEST impedance allowed for the amp.
http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&WT.z_homepage_link=hp_go_button&KeyWords=polyfuse
Set the filter to search for "Radial" type package and find suitable rating in the list that comes up.
Peavey 14 bt mixer won't pan. Keeps sending signal to both outputs
If your Peavey 14 BT mixer is not allowing you to pan the audio signal and is sending the same signal to both outputs, there could be a few potential reasons for this issue. Here are some troubleshooting steps you can take to address the problem:
1. **Check the Pan Controls:** Make sure you're using the correct pan controls for the channels you're trying to pan. The pan controls are typically knobs labeled "Pan" or "Balance" on each channel strip. Ensure that they're set to the desired positions.
2. **Reset Pan Controls:** If you've already adjusted the pan controls and they're not working as expected, try resetting them to their center positions. This can help eliminate any accidental settings that might be causing the issue.
3. **Channel Routing:** Some mixers have routing options that can affect panning. Check if there are any routing switches or buttons that might be affecting the signal routing for each channel.
4. **Mono/Stereo Mode:** Some mixers have a mono/stereo mode switch that can affect panning. Make sure the mixer is in the appropriate mode for your setup.
5. **Master Pan Control:** Ensure that the master stereo output pan control is set to the center position. If it's panned to one side, it can affect the overall stereo output.
6. **Test Different Channels:** Try panning different channels to see if the issue is specific to one channel or affecting multiple channels.
7. **Firmware/Software Update:** If your mixer has digital components or software control, check if there are any firmware updates available. Sometimes, software updates can address functionality issues.
8. **Physical Damage or Wear:** Inspect the pan controls and associated circuitry for any physical damage or wear that could be causing the issue.
9. **Factory Reset:** If none of the above steps resolve the issue, you might consider performing a factory reset on the mixer. Be sure to back up any important settings before doing this.
10. **Professional Service:** If the problem persists after trying these steps, it might be a more complex internal issue that requires professional servicing. Contact Peavey's customer support or a qualified audio technician for further assistance.
Remember that the exact steps and controls can vary depending on the model of your Peavey mixer. Refer to the user manual for your specific model for more detailed information on troubleshooting and operation.
8/20/2023 2:15:59 PM •
Peavey Music
Answered
on Aug 20, 2023
Does the peavey xr-600b have phantom power
It does not have built-in phantom power. Phantom power is a method used to provide power to condenser microphones and other devices that require a small amount of power to operate.
It is important to note that the XR-600B have XLR inputs which are typically used for condenser microphones that require phantom power but it does not provide this feature. If you want to use a condenser microphone with the XR-600B, you'll need an external phantom power supply or an audio interface that provides phantom power.
1/12/2023 8:34:18 PM •
Peavey Music
Answered
on Jan 12, 2023
Peavey bass R1080052 looking for any info .
Peavey R1080052 is a bass guitar model produced by the Peavey company. It is part of the company's Classic series of instruments, which are designed to offer vintage-inspired tones and aesthetics at an affordable price. The R1080052 features a solid ash body, a maple neck with a rosewood fingerboard, and two single-coil pickups. It also has a vintage-style bridge and a set of open-gear tuners. This bass is known for its warm, punchy sound and comfortable, easy-to-play feel.
1/10/2023 12:11:58 AM •
Peavey Music
Answered
on Jan 10, 2023
