20 Most Recent
Peavey Escort 3000 300 Watt Portable PA Speaker System Questions & Answers
I have a new Peavey
It sounds like the power supply is overheating, or an interconnect is becoming loose due to excess heat. This might be due to a faulty heat sensor, but counter-intuitively could also be due to a low voltage supply, that is, drawing more power than the circuit can handle so the voltage drops. Please check that the outlet(s) you are plugging in to are rated to supply enough power.
Usb show no usable device
only top layer files are playable, the thing cannot steer through directories. and I think the drive needs to formatted as fat 16.
I am an electronics hobbyist. My Peavey Escort
Sounds like a regulator IC has blown. if you can replace these and then check the output before putting the caps in you can find out. You may have taken other circuitry out if it was enough over-voltage to cause the caps to blow.
The system does not power on. When the power
Hi,Replace the caps and this time disconnect power supply rails that go to the amp module, then check positive rail for +30V and -30V, if they are present then your power amp ic's that if i remember correct are TDA7293 are blown, or at least one of them, let me know your results.
I can only get sound
This can be speakers, cables, connectors or the finals in your amp. First is just switch the speakers. That rules out the speaker etc. Just swap the leads from right to left etc. So the working setup is on the suspect bad output. If it works then the problem is something towards the speaker. If not its the amp. You can then try switching just cables to rule those out. Should take just a few minutes to figure out what the problem is. If it is the amp end check for dumb stuff like switches or the volume ;-] If not its a trip to your repair shop. Cables and contacts can be easily damaged and are the first suspect. Speakers are usually bullet proof unless you do everything maxed out. Amps will have issues due to age or heating etc. Just make sure to check out the amp value before telling anyone to fix it. You don;t want a big repair bill to fix a inexpensive amp, just replace it.
Peavey 14 bt mixer won't pan. Keeps sending signal to both outputs
If your Peavey 14 BT mixer is not allowing you to pan the audio signal and is sending the same signal to both outputs, there could be a few potential reasons for this issue. Here are some troubleshooting steps you can take to address the problem:
1. **Check the Pan Controls:** Make sure you're using the correct pan controls for the channels you're trying to pan. The pan controls are typically knobs labeled "Pan" or "Balance" on each channel strip. Ensure that they're set to the desired positions.
2. **Reset Pan Controls:** If you've already adjusted the pan controls and they're not working as expected, try resetting them to their center positions. This can help eliminate any accidental settings that might be causing the issue.
3. **Channel Routing:** Some mixers have routing options that can affect panning. Check if there are any routing switches or buttons that might be affecting the signal routing for each channel.
4. **Mono/Stereo Mode:** Some mixers have a mono/stereo mode switch that can affect panning. Make sure the mixer is in the appropriate mode for your setup.
5. **Master Pan Control:** Ensure that the master stereo output pan control is set to the center position. If it's panned to one side, it can affect the overall stereo output.
6. **Test Different Channels:** Try panning different channels to see if the issue is specific to one channel or affecting multiple channels.
7. **Firmware/Software Update:** If your mixer has digital components or software control, check if there are any firmware updates available. Sometimes, software updates can address functionality issues.
8. **Physical Damage or Wear:** Inspect the pan controls and associated circuitry for any physical damage or wear that could be causing the issue.
9. **Factory Reset:** If none of the above steps resolve the issue, you might consider performing a factory reset on the mixer. Be sure to back up any important settings before doing this.
10. **Professional Service:** If the problem persists after trying these steps, it might be a more complex internal issue that requires professional servicing. Contact Peavey's customer support or a qualified audio technician for further assistance.
Remember that the exact steps and controls can vary depending on the model of your Peavey mixer. Refer to the user manual for your specific model for more detailed information on troubleshooting and operation.
8/20/2023 2:15:59 PM •
Peavey Music
Answered
on Aug 20, 2023
