20 Most Recent Peavey Pv 2600 Power Amplifier Questions & Answers
Trying to locate the fuse on my tnt 160 Peavey bass amp
It's on the rear panel - between the power cord and the on-off power switch.
12/26/2018 7:11:34 PM • Peavey Pv 2600... • Answered on Dec 26, 2018
2answers
What is DDT my system cuts out when DDT lights up
Go to http://peavey.com/support/searchmanuals/archived.cfm Their main site also has info. DDT is an active compression feature to protect the product .
3/8/2016 8:38:05 PM • Peavey Pv 2600... • Answered on Mar 08, 2016
2answers
Karaoke repair
shop time
2/18/2016 2:26:38 AM • Peavey Pv 2600... • Answered on Feb 18, 2016
Wiring diagram
Contact Peavey toll free at 877-732-8391 or by email at [email protected],
1/20/2015 5:13:23 PM • Peavey Pv 2600... • Answered on Jan 20, 2015
What is the replacement of transistor d1915
IS that a 2SD1915 or something else, it looks like an 2SA1022 or NTE2407crosses - Newark Electronics or Mouser might be able to provide you a different cross reference. There are data sheets that seem to indicate a A1022 / NTE 2407 - this one can be found here http://www.mouser.com/Search/Refine.aspx?Keyword=2SA1022 Amplifier Transistor - these are common I think for older amplifiers. If memory serves me right - I probably have a couple old ones I bought to fix a Reel to Reel .
11/17/2014 4:50:38 AM • Peavey Pv 2600... • Answered on Nov 17, 2014
My ddt light does not work on left side
is the amp working, maybe the diode is out...maybe the connection to the diode is broken...
9/20/2014 4:55:04 AM • Peavey Pv 2600... • Answered on Sep 20, 2014
Connect audio source to the amplifier input, no sound
are you using the 1/4 in jacks or the balanced inputs.
9/20/2014 4:20:28 AM • Peavey Pv 2600... • Answered on Sep 20, 2014
How to connect subs and mains to the same pv2600
This will depend on your Subs. If they have an inbuilt crossover there will be input and outputs on the rear, with the output marked something like 'tops' or 'Output to HF' If you have these then it should be a simple matter of connecting yout amp to the subs and then the mains to the output. If you haven't got a crossover in the subs then you will either need to buy a pair of two way crossovers for the right power and frequency and have these in the speaker wiring or use the amp's inbuilt crossover and run one channel for tops and the other for subs. You will lose stereo but the amp will happily drive a 2ohm load so you should still be able to use all four speakers.
2/9/2014 5:14:40 PM • Peavey Pv 2600... • Answered on Feb 09, 2014
0answers
One chanel of my pv 2600 amp is playing very low
As a starting point clean ALL switches on the back of your amp, including the Stereo/Bridge switch then re-check functionality, good luck.
11/7/2013 2:43:24 AM • Peavey Pv 2600... • Answered on Nov 07, 2013
Can one(1) Peavy PV 2600 amp provide enough power
It should be able to do this. You would need to put each type speaker on a seperate side and then use either an elctronic crossover or an EQ set to pass only lows into the side for the subwoofer to block sending highs to the subs.
11/7/2013 12:12:22 AM • Peavey Pv 2600... • Answered on Nov 07, 2013
3answers
TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
11/6/2013 4:07:41 AM • Peavey Pv 2600... • Answered on Nov 06, 2013
Hello,Clean all back switches first of all, use a cleaning solution spray and give a 3 shot per switch, then push in-n-out several times each one and check amp functionality again.
11/5/2013 11:28:05 PM • Peavey Pv 2600... • Answered on Nov 05, 2013
One side stopped workig on
Hi,Please be advice that the center output connector is only for BRIDGE mode operation, you should not use that way, try to clean all the back switches with a cleaning solution spray, clean all switches and check amp functionality again in stereo mode.
11/5/2013 11:26:31 PM • Peavey Pv 2600... • Answered on Nov 05, 2013
I need a Peavey 8.5
Here is the service manual, scroll down and clic "Get Manual"http://elektrotanya.com/peavey_pv-8.5c_sch.pdf/download.htmlHope this helps.
11/5/2013 11:24:18 PM • Peavey Pv 2600... • Answered on Nov 05, 2013
My pv2000 amp stop working on one side
Please add more background, which channel stop working?As a blind advice, try to clean ALL back switches, including Stereo/Bridge Switch, let me know your results.
11/5/2013 11:19:07 PM • Peavey Pv 2600... • Answered on Nov 05, 2013
Why my amp is protecting after 4 hours
Soft start relay circuitry fail, take apart the top plate and when you turn the amp on check for a "Click" in the power supply relay, if not there's your issue.
11/5/2013 11:17:49 PM • Peavey Pv 2600... • Answered on Nov 05, 2013
Peavey Pv 2600 Power Amplifier Logo
97 questions posted
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
View Most Popular
Peavey Music
  • Peavey Music
Most Popular Question
ddt light one channel stays
  • Music
