20 Most Recent Norcent Technologies2703 27" TV Questions & Answers
0answers
No audio from tv.
Be the first to answer 1/28/2018 12:27:03 PM • Norcent... • Posted on Jan 28, 2018Be the first to answer
2answers
NORCENT PT -4233
Norcent PT4233 no picture, black screen, but has sound. How to repair
The display (PDP - Plasma Display Panel) at the heart of this unit is a LG 42V7 model. There is a known bad solder "defect" on the YSUS board that causes this board to fall unexpectedly.
The bad news is that you have to replace all the primary boards on the display - ZSUS, YSUS and CTRL boards, as the failure can/often takes them all out.
The good news is that LG makes a repair kit for this panel. Its part number is 687VSNB03E and it contains the three boards LG6871QYH036D (Y SUSTAIN), LG6871QZH041B (Z SUSTAIN) and LG6871QCH053G (CTRL).
Hope this helps
1/24/2015 1:59:37 AM • Norcent... • Answered on Jan 24, 2015
Need the code for a norcent tv with my unimote controler
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
12/22/2014 7:30:15 AM • Norcent... • Answered on Dec 22, 2014
Where is HDMI Connection?
look at your user`s manual if your unit have that features,then look in manual where is tha exact location of hdmi port...but mostly it is covered with small folding cover.if you notice some small covered on top or some where at the side
1/31/2014 11:13:08 AM • Norcent... • Answered on Jan 31, 2014
2answers
Remote stopped working. bought 2 universal
norcent.com
6/22/2013 2:31:12 PM • Norcent... • Answered on Jun 22, 2013
I need a base for Norcent LT-2231
Contact the authorized s dealer for Norcent.
4/2/2013 8:40:44 AM • Norcent... • Answered on Apr 02, 2013
Why can't i connect my windows 7 laptop to my tv
you must see the owner manual from your laptop or TV how to connect However see this diagram.and proceed according.God bless you10_18_2012_12_29_45_pm.jpg
10/18/2012 12:29:51 PM • Norcent... • Answered on Oct 18, 2012
Can't get closed captioning to go away,,, can't find it on the menue does anyone know how
Check whether there is a "CC" button on the remote control. If you are using a universal remote control, it might not have this button. As there is no selection for closed caption in the TV menu options, its original remote control will have this CC button. If you are the original remote, press this button once.
6/9/2012 5:20:41 AM • Norcent... • Answered on Jun 09, 2012
No picture on Norcent LT-2790 bk
There are two possibilities for this fault. The first one is with it deflection yoke connection. If this connection have any loose contact at main board side, horizontal sweep pulses will be absent to deflection yoke. Check this plug in connection first. If it is OK, check and replace the CRT connection socket.
6/4/2012 4:40:07 PM • Norcent... • Answered on Jun 04, 2012
Do I need a digital analog converter for this TV
You can buy it from any electronic goods selling shops at your town.
4/28/2012 2:44:00 AM • Norcent... • Answered on Apr 28, 2012
I try to use my
you need to set the computer to display on another monitor. You don't say what kind of compture you are trying to hook up, but generally if you right click on your screen and then click either "settings" if XP or "screen resolution" if Windows 7 you can find an option to use the tv as a monitor. most laptops will have the option to "display on projector" option. These alll vary with each computer model, but you have to tell the computer to display on your tv, most won't do it automatically
3/16/2011 8:53:34 PM • Norcent... • Answered on Mar 16, 2011
Need a remote control for
Hello
Just buy one PHILIPS UNIVERSAL REMOTE CONTROL MODEL NUMBER [CL 034]. Your Norcent TV is listed it its codes. Codes are:
0223 0905 0207
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
2/16/2011 10:07:47 AM • Norcent... • Answered on Feb 16, 2011
2answers
I turned the tv on
you probably blew the fuse because the reason its not coming on is its not getting power and the fuse will blow to protect everything else
11/25/2010 5:32:44 PM • Norcent... • Answered on Nov 25, 2010
The remote will not turn
The problem is not with the remote, your set has developed a fault, and it has been shut down.
This is a switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
OK well what has happened i suspect, is that your set has been "Spiked" from a power disturbance, and this has damaged either the PSU, or an internal high voltage component, or both, and now, the Protection Circuitry in the SMPS unit, is "Sensing" a potential "Catastrophic fault", that may cause a fire an explosion or both, and accordingly the set MUST be shut down, so the protection circuitry does exactly that.
Your best bet, is to contact a local or head office of the TV's manufacturer, and ask them for a referral to an authorised servicing center. When contact is made with them, ask for a "Quote" for the repair, before allowing any repair work to be undertaken. This then at least will give you an idea as to costings and you can then make an informed decision as to repair or replace, as often these days i find in my shop anyway, many repairs can be very expensive, and often it would be better putting any monies that would have been spent on repair towards a NEW unit with a warranty.
11/18/2010 4:59:02 AM • Norcent... • Answered on Nov 18, 2010
Sound no pic. after on
Your TVs CRT socket is faulty. CRT socket is one that connect the base of the picture tube, and can be located on the base card of the tv. It is soldered directly to base card and can be replaced. Unplug the base card from the picture tube neck [Caution: never damage the neck of the picture tube. Only slight pressure should be applied], desolder it out and replace it with a similar type.
10/17/2010 2:36:17 PM • Norcent... • Answered on Oct 17, 2010
2answers
I own a Norcent TV model LT-1931. I am a DirectTV
Out of range = the tv receives a signal with a resolution higher than it can display. Connect your DirectTV to another tv and make sure that the signal is one supported by your tv (any SD format will do). If it is then connect your tv to a pc and test the supported resolutions - if none work or the image is bad then the storm has fried its image processor - a repairman should take a look at it.
9/11/2010 5:48:27 AM • Norcent... • Answered on Sep 11, 2010
Green and blue stripes in the picture
turn tv on, press the menu button.
look at picture if the lines are in front of the menu problems most likly the display ,if the lines are behind the menu its the vido module
hope this helps
9/8/2010 5:13:40 AM • Norcent... • Answered on Sep 08, 2010
3answers
Big problem with Norcent pt4233
call 905 565 6595 to get fix
8/2/2010 5:08:40 PM • Norcent... • Answered on Aug 02, 2010
Norcent TV codes
hi! i have here a codefor your tv, just try it 1217, hope this helps! goodluck!
6/6/2010 12:27:51 PM • Norcent... • Answered on Jun 06, 2010
Trying to reset tv for use on outside antenna from
Hi
Thanks for using FixYa. The default code is 1111. As you are not aware of the password, please follow this procedure---
POWER (OFF) -> MENU -> V-CHIP-> MUTE” to revert to the default password. Please follow the instructions on the screen to change it. Once changed, please remember it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
5/27/2010 6:27:26 PM • Norcent... • Answered on May 27, 2010
Norcent Technologies2703 27" TV Logo
40 questions posted
Top Norcent Technologies Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
ADMIN Andrew
ADMIN Andrew
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Norcent Technologies Televison & Video
Most Popular Question
39 t get closed captioning go away
  • Televison & Video
