20 Most Recent
Norcent Technologies LT-2722 27 in. LCD Television Questions & Answers
My tv says invalid mode for 10 min before I can
try a factory reset. it may be a fault when turning on. also it can happen more if left in standby mode. every now and then turn the power off completely overnight, this will discharge the capacitors and remove the static build up that can affect the bios of the tv.
2/28/2018 3:05:08 AM •
Norcent...
Answered
on Feb 28, 2018
Norcent LT 2723 LCD 27"
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/13/2017 4:22:35 PM •
Norcent...
Answered
on Jul 13, 2017
My Norcent LCD TV LT2722
Green "ON" lights comes on (after some jiggling of the on/off button). Nothing else. Black screen, no sound. Where should I go next?
7/26/2013 7:18:22 PM •
Norcent...
Answered
on Jul 26, 2013
How can i get a replacement remote control unit
I have a remote for my norcent tv, My tv is at home, I am on the road, I have found a remote but I do not know if it will work on my tv. The number I found on the remote is 681T where the batteries go. Which tv does this remote work. Thanks in advance, Mark
3/14/2013 1:49:53 PM •
Norcent...
Answered
on Mar 14, 2013
LT 3751 change the power board still no picture
Hello Jason:Check the inverter board for blown fuses in will be a micro surface mount fuse, if it is blown then replace the inverter board assembly. The inverter is used to light the back lights of the screen. Also check the supply voltage from the power supply to the inverter should be between 12volts to 30 volts.Also you if the inverter board checks ok , then your problem lies in the T-Con board this board is at the top to the panel under a shield.
10/18/2011 2:42:27 AM •
Norcent...
Answered
on Oct 18, 2011
I HAVE A NORCENT LCD TV . I MOVED IT FROM ONE ROOM
All you have to do is to open the back cover of the television and check connectors that are loosen that is not intact , this is the likely problem that may occur , since the television is working before .
Hope this helpout . Good luck
7/3/2010 3:25:47 AM •
Norcent...
Answered
on Jul 03, 2010
My TV changes channels or source by itself. I
This may or may not be your solution.
The tact switches (push buttons) mounted on the circuit board may need to be replaced (old, worn, sticking). These are the buttons that are pressed in when you use the controls on the television set (volume, menu, channels etc.). Try removing all of these switches (don't remove the remote sensor). Don't remove just the channel switches.
If you have a remote than you don't 'have' to replace them, only if you want to control the tv from the set itself. After you remove them see if you have the same issue. If so you may need a new control IC chip.
A repair shop will charge about $75 to replace the buttons. If you have the tools and knowledge than feel free to do it yourself. To remove mine, I just used pliers and was careful. However to replace them you will need a soldering iron.
3/2/2010 12:59:39 AM •
Norcent...
Answered
on Mar 02, 2010
Does the norcent lt 2722 model have an hd tuner
Yes,all LCD tvs have tuner build in.To recieve DTV free air channels without a converter box.Full HD tvs can get show in mode 1080i,here are some channels play show in 1080i mode are CBS,NBC,CW.
2/21/2010 2:02:18 AM •
Norcent...
Answered
on Feb 21, 2010
