20 Most Recent
Norcent Technologies LT-3222 32 in. LCD Television Questions & Answers
No volume on my norcent television
check the simple things first:Do you have sound when a DVD ETC is connected via rear inputs for audio and video?Look to see if speakers in set are switched ON or OFF.Look to see if volume is down or very low both on the set and a box if one is used.If set has connections for external speakers is it set Internal or External.
5/16/2012 3:17:26 PM •
Norcent...
Answered
on May 16, 2012
Blue power light comes on the tv will not come on
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.......
5/7/2011 5:48:43 PM •
Norcent...
Answered
on May 07, 2011
My tl3222 norcent whent black.Good sound.any
This sounds like a problem with the power supply. Usually capacitors on the power supply board tend to dome, bulge or dry up. The damaged ones can be seen on the power supply circuit board when the back is removed. The dry ones have to be removed and tested. The caps can be replaced at a repair shop for around $200, but if the power supply board has to be replaced it can cost a little more. It all depends on the shops repair fees. But you could also have a bad main/control board which is where all the input jacks and tuner are mounted. These boards are more expensive, but not sure of the actual cost.
4/11/2011 10:02:54 AM •
Norcent...
Answered
on Apr 11, 2011
We will be watching a
if this keeps on happening its a signal of the main board going bad and / or the screen going bad on the tv.
3/23/2011 5:58:42 PM •
Norcent...
Answered
on Mar 23, 2011
My tv will not turn
Try unplugging it wait 5 minutes holdd the power button while plugging it in see what it does
1/27/2011 10:40:03 PM •
Norcent...
Answered
on Jan 27, 2011
How do i get a new remote
Okay couple options here:
!. buy a universal
2.
www.remotes.com will have your factory remote for htis unit.
I sure hope this helps and may God bless you and you family, Please do give your 4 thumbs up for my unwavering support for your FREE answer to your question and leave some feedback!! Thanks Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
11/24/2009 6:43:27 PM •
Norcent...
Answered
on Nov 24, 2009
Picture is out but audio works
Don't be bothered by not being Mr. Fix It. Unless you have the specific experience you really shouldn't try to repair one of these newer flat screen LCD, plasma, and rear projections. If your picture has gone out, there is a part inside--a circuit board or the capacitors on it--that needs to be replaced.
If you don't have an extended warranty, know that the repair will cost you a minimum of between $200 and $300. However, be warned that the total cost could be considerably higher. It really depends on the price of the replacement part. And on some TV's a board might cost $327 while the same board in another brand may be 3 times that much.
First, you have to take the unit to a repairman to discover how many parts are going to be needed to complete the repair.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
7/13/2009 2:14:42 AM •
Norcent...
Answered
on Jul 13, 2009
