20 Most Recent Lenovo IdeaPad Y450 Notebook Questions & Answers
How do i change my lenovo latop from chinese to english?
Dear Costmer, Go to the "Start" menu, then choose "Settings," "Control Panel" and "Regional and Language Options." Click the "Languages" tab, then the "Details" button, the "Settings" tab and the "Add" button. Choose an input language from the list. You can choose ANY language. For example, if English (US) is the "input language," check the "Keyboard layout/IME" box to select the US-International English keyboard from the list. Click "OK" and close the input window. A language indicator should appear in the System Tray (the area in the bottom right hand corner of the desktop). Switch between input languages by pressing the "Alt" and "Shift" keys simultaneously. Click "Apply" to finish the process and finalize your choices. You shouldn't need the Windows installation CD for this process. [email protected]
2/13/2015 10:58:46 AM • Lenovo IdeaPad... • Answered on Feb 13, 2015
Bios password
This is supposed to be impossible, but there is a way to do it. Unscrew the case, locate the CMOS backup battery, remove it. Leave it out for a minute or so as to allow the capacitors enough time to discharge. Restore the CMOS battery to it's original position, screw the case back together, and power on the computer. Your BIOS password should be removed. Keep in mind that this will also restore all BIOS settings to factory defaults.
11/8/2013 10:11:42 PM • Lenovo IdeaPad... • Answered on Nov 08, 2013
My lenovo ideapad y450 isconnected but isn't
What percent (%) has it stopped charging at? Some lenovo's stop at about 60%.
10/6/2013 2:48:30 PM • Lenovo IdeaPad... • Answered on Oct 06, 2013
0answers
Lenovo idea pad won't charge or run plugged in
Is the cord and Battery the EXACT same power spec? If so, it may be the AC jack in the Laptop has been damaged due to pulling on the cord while plugged in, broken connection.
4/11/2013 6:33:21 PM • Lenovo IdeaPad... • Answered on Apr 11, 2013
Intergrated webcam not working
In what? If you open the Lenovo supplied webcam software does it work? CyberLink ? Check Device Manager, Imaging Devices, is it enabled? driver up to date?
12/31/2012 1:45:23 AM • Lenovo IdeaPad... • Answered on Dec 31, 2012
2answers
My laptop is not charging. i plug the power in but still doenst charge. im not sure if its on the power cords or on the laptop please help asap i need my laptop for school :(
Does the laptop work on AC ? Is the battery or cord/charged a replacement? First, try another cord/charger of the EXACT same specs as original. Second, Is the battery good? How old? Over 4 years? Have it tested. Beware of inexpensive aftermarket batteries and cord/chargers. I assume the laptop works on AC? If you unplug the AC , with battery in, the laptop shuts down immediately?
11/27/2012 6:28:37 AM • Lenovo IdeaPad... • Answered on Nov 27, 2012
Black screen
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
9/16/2012 8:19:48 AM • Lenovo IdeaPad... • Answered on Sep 16, 2012
Mine just come out LENOVO then stop there. i press F2 @ F12 but not working. Plz help me
This sounds like a hard drive issue, if you have a windows backup disc try a fresh install, no luck! remove hardware and reseat back in place, this will sometimes solve the problem, no change! have the hard drive tested.
6/24/2012 12:28:09 AM • Lenovo IdeaPad... • Answered on Jun 24, 2012
Lenovo y450 not shutting down
go to download.com and download ccleaner, this will clean out all junk from the hard drive, next download smart defrag from the same location and defrag the hard drive. Both programs should improve performance, next check to see how many programs start up when windows start, if there are to many it greatly slows the shutdown time and some cases stalls, remove any programs not needed.
3/15/2012 1:29:18 AM • Lenovo IdeaPad... • Answered on Mar 15, 2012
Blue screen while gaming
Based on the error code, this issue has to dowith an external Hard drive working at high stress levels. Are you trying to run the games from a secondary HD? If so, try removing them and installing them on the primary HD.
1/5/2012 9:27:40 PM • Lenovo IdeaPad... • Answered on Jan 05, 2012
Hi My hard disk had crashed
Welcome to Fixya
You need to enable it at the Bios. Reboot the computer and press the button that will lead you to the BIOS menu of the motherboard. Go to System configuration and go to actions keys mode. Press enter then select "ENABLED". Save settings before you exit then test the issue.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
9/12/2011 2:56:11 AM • Lenovo IdeaPad... • Answered on Sep 12, 2011
My Fn + key is
it migt be turn off. try to press Fn + F1 + F2 + F3 + F4 + F5 + F6 + F7 + F8 + F9 + F10 + F11 + F12 to turn OFF or to turn ON. or you may go to BIOS to turn it on from there.
9/11/2011 5:39:51 AM • Lenovo IdeaPad... • Answered on Sep 11, 2011
3answers
I have lenovo y450 ideapad,,i
Hi! Welcome to www.fixya.com.
Its best to call Lenovo and order the recovery disc so you can revert your system to factory settings by reinstallinng the right OS for your system with is a OEM version of lenovo. At the moment. You can check http://support.lenovo.com/en_US/downloads/default.page? to get the the right driver for your system.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. God bless. Bye for now.
8/28/2011 12:49:14 PM • Lenovo IdeaPad... • Answered on Aug 28, 2011
2answers
I cannot hear any sound
Check your laptop keys for symbols - usually printed at the bottom of the f keys. If your laptop has a FN button or something similar, you may have mistakenly disabled the speakers WITHOUT muting the sound in Windows.
8/3/2011 1:02:22 AM • Lenovo IdeaPad... • Answered on Aug 03, 2011
Lenovo IdeaPad Y450 Notebook Logo
48 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
IdeaPad Lenovo
  • IdeaPad Lenovo
Most Popular Question
lenovo y450 ideapad
  • Computers & Internet
