20 Most Recent Lenovo IdeaPad Y430-3231U Notebook Questions & Answers
Lenovo Customer service Contact Lenovo online technician and diagnose your problem in free.
Lenovo IdeaPad... | Answered on Apr 04, 2016
Please ensure that the correct drivers for the wifi adapter are installed. T410's can have different wifi makes, and installing the wrong one will make the wifi inoperative. Ensure you grab the drivers from the Lenovo support site.
Lenovo IdeaPad... | Answered on Jul 13, 2015
If you have tried every USB port and you use another USB device to it.. You may check the device manager ryanpajaro20_7.jpg and check if the USB controllers are disabled.. If not, you may click View and then click Scan Hardware Changes.. If still won't work, that is time that you call lenovo and have you laptop replaced defective USB ports..
Lenovo IdeaPad... | Answered on Jan 05, 2015
Reinstall the driver
plug headphones and play a video or music file
if you hear it ok then the driver is installed ok
Laptops and netbooks IdeaPad Series laptops IdeaPad Y430 Lenovo Support...
check your settings
  1. Click Start and type "sound" into the search bar. A list of search matches is displayed.
  2. In the search results, click Sound under the Control Panel list.
The Sound screen is displayed.
Lenovo IdeaPad... | Answered on Aug 12, 2014
HERE: http://support.lenovo.com/en_US/research/hints-or-tips/detail.page?&DocID=HT072727
Lenovo IdeaPad... | Answered on Jul 30, 2014
Welcome to FixYa! The problem that you have is about the Operating system and there are two ways of fixing the problem which is by using the Recovery Disc or using the One Key Recovery Button. Please follow the steps below for you to be able to fix the problem. If everything is done and its still the same, most probably, the problem is with the Harddrive.
For One Key Recovery:
1. Turn off the computer.
2. Press the little button near the power button, it usually do have a drawing of an icon that looks like a horse shoe or a headset.
3. There will be a window that will appear which do have three option, One Key Antivirus, One Key Recovery and System Setup. Choose One key Recovery.
4. There will be another window that will appear which do have two option, Restore from initial backup and Restore from user backup,Choose Restore from initial back up
5. It will asked you if you want to continue, Just click on OK or YES.
6. Once done, Reboot the computer.
For Recovery Disc,
1. Insert the disc inside the drive.
2. Turn off the computer then turn it back on and keep on tapping F12
3. There will a window that will appear which do have three options, HDD,ODD/DVD/CD, and NAT, choose ODD/DVD/CD
4. It will asked you to press any key immediately, you will need to press any key immediately so that it will boot from ODD.
5. It will asked you to choose a partition, choose Disc 0 partition 1
6. Reboot computer once done.
I hope this information will be helpful. Thank you for using FixYa...
Lenovo IdeaPad... | Answered on Jun 10, 2014
You will need to redownload the drivers for the wifi adapter from the Lenovo website.
Lenovo IdeaPad... | Answered on Jan 06, 2014
Please check if you have installed a Lenovo Energy Management which can be found by clicking on START>ALL PROGRAMS>LENOVO>LENOVO ENERGY MANAGEMENT folder>LENOVO ENERGY MANAGEMENT, if you did use that to manage power options, that programs controls your power management and the Power Options on Control Panel is over-ridden by this program.
Lenovo IdeaPad... | Answered on May 24, 2013
turn the laptop upside down, you will usually see a rectangular panel with 1-2 screws, remove them and the hard drive will be in there, take it out and connect it to another computer, or buy a usb 2.5" caddy to put it in, then connect to other pc and all the information will be there.
Lenovo IdeaPad... | Answered on Jun 17, 2012
The jack for the charger has come loose inside the laptop. How do I repair it?
Lenovo IdeaPad... | Answered on Jun 06, 2012
Try installing the latest WEBcam driver.
The same model Lenovocan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your Lenovo, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive.Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows device drivers foryour model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Lenovo IdeaPad... | Answered on Jun 02, 2012
Please follow the diagnosis outlined in this article to check whether the backlight lamp or the inverter board are the root cause of the problem or not:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
If you connect the external monitor & nothing is displayed on it, then this means that both the backlight lamp & the inverter board are fine. The main indicators in these cases are the sound, and the hard drive LED on the laptop case. If the laptop sounds just like it always does for a minute or two after being turned on, it means it's going ahead and booting the operating system, but the video processor or part of the motherboard circuit for video output has failed. If the laptop just sits there and beeps when you turn it on, or if you hear the fan but not the hard drive chuckling with its active LED flashing away, it means the laptop isn't getting as far as trying to boot the operating system. While this could be due to any number of hardware problems, the most common and easiest to
troubleshoot or repair is RAM failure. If your laptop has two RAM modules installed, try booting with just one and then the other in the primary slot. If your laptop only has one RAM module, you might consider buying one online from a site with a good memory selector, like Crucial.com
Lenovo IdeaPad... | Answered on Aug 11, 2011
1. Turn off your compter.
2. Look for theOne Key Recovery button on your PC. It's near the power button.
3. Press the OKR button, wait until your computer turns on.
4. After Windows loading files you'll be routed on Lenovo One Key Rescue System.
5. Select One Key Recovery then, select restore from Intial back up.
Usually it will take 20-30 minutes for the whole process to be done. Once it's finish just reboot your computer.
If this fails, then call them.
http://www.lenovo.com/planetwide/select/selector.html
Lenovo IdeaPad... | Answered on May 13, 2011
Thank you for choosing FixYa!
I work for Lenovo and I know these computers very well. With your concern, I believe the wireless switch is on but still it tells you that you need to switch on the wireless device. Now, to fix this issue, do these:
1. Press and hold "Fn" on the lower left hand side of the keyboard, beside the space bar.
2. While holding "Fn" down press "F5".
By doing so, you have enabled the wireless capability of your computer. Enjoy surfing and thank you for visiting FixYa!
Lenovo IdeaPad... | Answered on Apr 16, 2011
Lenovo IdeaPad Y430-3231U Notebook Logo
83 questions posted
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
IdeaPad Lenovo
  • IdeaPad Lenovo
Most Popular Question
lenovo ideapad y430 repair r nthe jack
  • Computers & Internet
