20 Most Recent
Logitech Harmony 900 Remote Control Questions & Answers
I have a Harmony 900 the screen has gone blank and
Press and hold the Menu button (located above the Channel Up button) and the Off button together for 20 seconds. The remote screen will turn off, then turn on again displaying the image of a remote and a circular arrow. After a few seconds your remote will be restored to factory defaults and you may sync again.
When I replace the battery in my Harmony900 remote, do I have to re sync the remote and if so how
After replacing the battery, you have to set it up again with set-up code said for your device. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
How to set up my logitech remote
. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Remote was fully charged but is dead.. No display lights today. .?
make this test take some digital camera, point at camera with the remote control press any key and see if the LED i.r is ON. see the diagram attached. If NOT turn ON, the problem is poor contact with terminal batteries, clean. resolder the contacts. open the remote and clean the keypads for dirty, oxide, and resolder the contacts for LED.God bless you
Can't change channel, get to list, or guide with Logitech remote
open the remote control and clean the keypad for dirty, oxide, corrosion, and bad contacts.2) replace new batteries ALKALINE , full charge3) retigh the springs contacts batteries, with long pliers for better contacts.4) try again.5) otherwise you must go to the repair shop TV for fix it.God bless you
No blaster signal
Either a problem with the remote (something got spilled inside) or it is not capable of being programmed for the unit you are trying to use it on.Spills are common and will usually affect buttons close to each other.Got any more information for me?
