20 Most Recent Kenmore 15872 Dishwasher Questions & Answers
2answers
No water is getting to the dishwasher but the
Under neath your dishwasher, where the water hooks up to it there is a valve that has an electric coil on it. This valve opens and shuts to allow the water in your dishwasher. Make sure the screen in there is not plugged first. If you take the hose off it will be right there if you have one. If that all checks out okay then you need to replace your solenoid valve.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
5/29/2012 2:44:52 AM • Kenmore 15872... • Answered on May 29, 2012
2answers
Do you hook up to cold water or hot water
Hot water.
5/29/2012 2:25:58 AM • Kenmore 15872... • Answered on May 29, 2012
Standing water in bottom of dishwasher
Here is a tip that I wrote that will help you with your dishwasher not draining problem...Dishwasher Problems - Water will not drain outheatman101
11/17/2010 11:05:13 PM • Kenmore 15872... • Answered on Nov 17, 2010
2answers
The arms that spin both upper and lower do not
In case you do not have a user manual for your dishwasher you can load it form this site.
The actual model no. should be 665.15872.
This diswasher uses the same pump to circulate water and drain water. There might be a blockage in the pump assembly which is preventing the water from entering the arms and spining them.
I am assuming you do hear the pump running. You will have to open the pump and spray assembly to get inside and find out if the blockage is in the chopper. The parts should look like these on this website. You will have to open the side panels to access the base and bottom to get to the pump assembly.
Hope this helps. Please rate the solution if helpful otherwise post a comment.
11/1/2010 10:33:57 PM • Kenmore 15872... • Answered on Nov 01, 2010
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
10/16/2010 3:21:15 PM • Kenmore 15872... • Answered on Oct 16, 2010
Can get soap dispenser open
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....Dishwasher Repair Problem Detergent Cup does not Openheatman101
9/30/2010 11:40:29 AM • Kenmore 15872... • Answered on Sep 30, 2010
My dishes are not getting clean, the cycle seems
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Please rate the solution if you feel I've helped you
9/10/2010 5:32:17 AM • Kenmore 15872... • Answered on Sep 10, 2010
Water not draining from bottom of dishwasher.
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
6/25/2010 2:47:58 AM • Kenmore 15872... • Answered on Jun 25, 2010
Trying to remove the filter screen to see if something is blocking
Try a Torx screw driver. It looks like an Allen but it is a star shape head.
4/4/2008 12:05:50 AM • Kenmore 15872... • Answered on Apr 04, 2008
Replacing seal
What is the model number
12/29/2007 6:14:10 AM • Kenmore 15872... • Answered on Dec 29, 2007
My older built in Kenmore 3380957 Rev.A dishwasher.
If it is doing when it is washing, then it likely to be a problem with the pump, but it might just be 'hunting' because the filters are partially blocked. There is the filter that you can see easily, but there is a fine filter underneath that blocks with fine grey lint. Water left in the bottom can be caused by that because the drain pump is past the filter and is on a timer. https://www.google.com/search?q=Kenmore+3380957 ..
3/2/2024 4:32:03 AM • Kenmore... • Answered on Mar 02, 2024
Hinges are very noisy when opening or closing door of my Kenmore dishwasher model 587.1527. What can I check to resolve problem?
To open the Kenmore World class dishwasher, follow these means:
Press-and-hold down the "Sani-Wash" button for somewhere around three seconds until the showcase screen counts down from three to nothing. The red "Lock" Drove ought to now douse and you ought to now have the option to get to each of the buttons on the control center.
10/14/2023 9:30:27 PM • Kenmore... • Answered on Oct 14, 2023
Kenmore 15872 Dishwasher Logo
25 questions posted
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dishwashers
  • Kenmore Dishwashers
Most Popular Question
arms spin both upper lower not
  • Dishwashers
