20 Most Recent
Apple MB985LLA 15.4" Macbook Pro Notebook Notebook Questions & Answers
How do I restart my
If holding the power button for 5 seconds doesn't work, then only taking the battery out
I just installed a new
Try printing whatever you were wanting to print but click the drop down arrow right next to the printer selection tab. Then you should see a drop down menu about halfway down the menu, click it and select print settings. You should see another drop down menu called color, just click it and change it from grayscale to color.
Hope this helps,
Justin
I have a hp deskjet
In the print menu (Command P), there is a drop-down menu toward the bottom of the screen.
One of the options is Quality & Media. Under this option, make sure that greyscale is not selected.
I hope that works for you!
How can I change the setting from grayscale so
Go to print as per normal under the drop down box beneath the number of pages. In firefox the drop down box would be firefox and then in the drop down menu select Paper Type/Quality then change the color from grayscale to whatever color options come up. Hope this helps.
My Mac wont print color to my HP printer.
There is a setting in the print dialogue that allows you to set that the printer prints only in grayscale. There is a chance that you have that setting changed and it is printing in grayscale each time you print by default.
I dropped my mac lap top and the screen is a bit fuzzy, how can I fix it?
Thank for contacting Fixya, I will be glad to assist you. You cannot, without having a diagnostics performed by a certified Apple technician or Apple Authorized Service Provider. You may have damaged the video graphics card on the main logic board of your MacbookMacbook Pro.Unless you have knowledge on how to go in and physically troubleshoot this geniune hardware issue, I would recommend you do you to your local Apple retail store Genius bar, or Apple Authorized Service center near you and have your Macbook looked at.Just for your reference, I have taken the liberty to provide the store locator links to your local Apple Retail store as well as a general store locator for locating any local Apple Authorized Service center in your area.
Apple Retail Store(Genius bar - need to set appointment via this website link, if planning on visiting Apple store of choice in your immediate area)
Apple Authorized Service ProviderYou don't want to keep turning on the Macbook until you have it checked because it could affect more than just the video graphics card.Regards,-The MacTechTrainer.
I have a Sanyo Xacti 10 MP that records with date and time but when I put the SD card in my Apple laptop and download the videos, the date and time seems to not stay on the videos.
The date and time information may not be embedded in the video file itself, but rather in the metadata of the file. When you transfer the video from your camera to your computer, the metadata may not be transferred along with the video.
To preserve the date and time information on your downloaded videos, you can try the following:
- Use a video player that displays metadata: Some media players, such as VLC media player, allow you to view the metadata of a video file. If the metadata contains the date and time information, you may be able to view it using such a player.
- Transfer the video using a program that preserves metadata: Some file transfer programs, such as Image Capture on Mac, will preserve metadata when transferring files. You may try using such a program to transfer your videos.
- Use a metadata editor to add date and time information: You can try using a metadata editor, such as ExifTool, to add the date and time information to your video files.
It's worth noting that not all video file formats support metadata, so depending on the format of your video files, it may not be possible to preserve the date and time information.
How to factory reset iMac without login or keyboard?
To factory reset an iMac without a login or keyboard, you can try the following steps:
- Boot the iMac in Target Disk Mode: Connect the iMac to another Mac using a Thunderbolt cable. Power on the iMac while holding down the T key. The iMac should appear as an external disk on the other Mac.
- Reinstall macOS: Open the Disk Utility app on the other Mac and select the iMac disk. Choose "Erase" and follow the on-screen instructions to erase the iMac's drive. After erasing, quit Disk Utility and follow the on-screen instructions to reinstall macOS.
- Restore from Time Machine Backup: If you have a Time Machine backup of the iMac, you can restore the backup to the iMac after reinstalling macOS.
If these steps don't work, you may need to seek assistance from an Apple Store or a professional repair service.
I have a new MacMini 2021 Monterrey O/S. I use Zoom but my Gear Head Webcam F#2 4.8mm is not on or is not connecting? IS it compatible with Apple Monterrey O/S?
It's possible that your Gear Head Webcam F#2 4.8mm is not compatible with the new MacMini 2021 running the Monterrey operating system (macOS Monterey).
The best way to check for compatibility is to visit Gear Head website and check for the compatibility list for the webcam with the MacMini 2021 running the Monterrey operating system. If the webcam is not on the list, it's possible that it may not be compatible with the new operating system.
If the webcam is not compatible with the new operating system, it may not be able to connect to the MacMini or be recognized by the Zoom app.
Alternatively, you can try connecting the webcam to the MacMini using a USB-C adapter and see if that resolves the issue.
You may also want to check if there is any new firmware update available for the webcam or the Zoom app that might resolve the issue.
If the issue still persists, it would be best to contact Gear Head customer support for further assistance and check if there is a way to make the webcam compatible with the new operating system or if there is any other solution that can be provided.
