20 Most Recent Juki MO-735 Mechanical Sewing Machine Questions & Answers
How do I adjust the bottom thread tension on the 2 needle cover stitch?
Go back to the tension adjustments that were doing well with other fabrics. You may need to go to a smaller size needle, and a finer thread. Sometimes I use a wooly nylon in my looper because it is very stretchy, but be careful when you pull it through as you are threading it because it will also break easily if you don't have your tensions full open as you are pulling it through. Start out by buying a sheet or roll of Solvy. You can either cut it into strips to lay on top of the material as you sew or under it if you prefer. It should make the material lay flat as it sews. I have used tissue paper before under it to make it lay flat and keep it flat to make the looper thread stretch itself out as it sews. If your looper thread tension was too tight on other fabrics too, that is a whole other problem.
10/5/2017 11:46:45 AM • Juki MO-735... • Answered on Oct 05, 2017
I bought Juki MO-735 serger on eBay (new, brom
Go back to the seller. If it was listed as new and does not work, the seller should either repair, replace, or refund. Note--you may need to get eBay involved in case the seller refuses to address the issue. EBay will refund your money and reverse the charge to the seller.
7/17/2017 3:17:52 PM • Juki MO-735... • Answered on Jul 17, 2017
Refuses to sew has been stored for a while
Please get it serviced. The oil evaporates and leaves a sticky film that gums things up. :-(
2/14/2015 12:41:02 AM • Juki MO-735... • Answered on Feb 14, 2015
Machine breck Dowan
Have it repaired by a trained Juki machine technician.... Too expensive to try yourself.
2/3/2014 7:22:45 AM • Juki MO-735... • Answered on Feb 03, 2014
0answers
My yuki serger run too
Domestic sergers usually sew 1500 stitches per minute, you can't increase this. You can make the stitch longer which will move a bit more fabric through with each stitch but obviously you need the stitch to hold the fabric too.
If you find this is not fast enough for the volume of work you need to do, then shop around for an industrial machine. Usually built into a table, and designed to feed very fast. Try the Juki website, they do a big range of industrial machines such as these http://www.juki.co.jp/industrial_e/products_e/apparel_e/cat6/
6/13/2011 4:24:26 AM • Juki MO-735... • Answered on Jun 13, 2011
I just bought a refurbished juki 735 and when I
Is the front cover closet ?
10/12/2010 7:06:37 PM • Juki MO-735... • Answered on Oct 12, 2010
Juki MO-735 lights up but will not sew. I do not
Is the front cover closed?
6/29/2010 5:07:36 PM • Juki MO-735... • Answered on Jun 29, 2010
Don't know how to thread the juki mo-735 serger
This video starts off a little ****, but expected if you have ever visited the Threadbanger site - http://www.metacafe.com/watch/1462325/how_to_use_a_serger_indie_pendent_designer_spotlight_thread_he/ Not your brand, but the same "serger basics". Lift the antenna to it's highest position. Set the tensions to zero. Have the presser foot up when threading. Raise the upper looper to it's highest position. Sergers are great little machines, but they can be nerve racking when it comes to threading. After years of threatening my old FunLock, I bought a Babylock Imagine with air-jet threading - what a relief!
3/12/2010 9:58:41 PM • Juki MO-735... • Answered on Mar 12, 2010
Need a "How to Guide"
Visit us at www.ifixmachine.com
7/24/2009 2:07:25 AM • Juki MO-735... • Answered on Jul 24, 2009
Hello, please give me the juki support link.
https://jukiamericas.com/pages/supportif you live in the USA or https://jukiindustrial.co.uk/support/ for the UK and Europe.
3/24/2024 12:14:48 PM • Juki Sewing... • Answered on Mar 24, 2024
Juki MO-735 Mechanical Sewing Machine Logo
28 questions posted
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Juki Sewing Machines
Most Popular Question
refuses sew stored while
  • Sewing Machines
