20 Most Recent Dimplex DGWH4031 Heater Questions & Answers
How do I run the 220 wires to a plug for the heater?
Please contact an electrician as this requires a special breaker in your breaker panel to be installed and different wiring.
10/9/2014 10:09:32 PM • Dimplex DGWH4031... • Answered on Oct 09, 2014
THE FAN MOTOR IS MAKING A LOUD NOISE CAN I REPLACE
Yes, many parts on the web.
12/30/2013 12:09:53 AM • Dimplex DGWH4031... • Answered on Dec 30, 2013
My dimplex fireplace is too
I have been dealing with electric fireplace/heaters for several years, now. And for the life of me, I can not think of a thing that would cause a noise like a 747 jet plane. Could you be a little more specific as to which function of the fireplace cause this noise?
Look forward to hearing from you.
5/7/2011 3:20:49 AM • Dimplex DGWH4031... • Answered on May 07, 2011
Our garage heater will not
Is a thermostat used?
1/12/2011 1:56:58 PM • Dimplex DGWH4031... • Answered on Jan 12, 2011
Where can I find
I have been lucky using Grainger they usually have these items in stock or can locate them quite quickly.
12/13/2010 12:52:04 PM • Dimplex DGWH4031... • Answered on Dec 13, 2010
Looking for ainstlation diagram for installing a
try the dimplex web site ,that may help
7/6/2010 9:10:21 AM • Dimplex DGWH4031... • Answered on Jul 06, 2010
Have a new Dimplex DGWH4031 heater in the garage
Sounds like the fan blade is hitting something
1/2/2010 6:46:28 PM • Dimplex DGWH4031... • Answered on Jan 02, 2010
I do not know how to wire the plug box from my
Hi, I am not completely Sure what you mean, but will explain the connections. First, from your breaker box if you are trying to wire a 3-pole cord and plug to the breaker, you will be dealing with 3 wires, more then likely, Red -Hot, black-Hot, and white Neutral. If you have a 30amp 2-pole breaker, make sure it is off and red goes to one leg of the breaker, black to the other, and white to the ground or neutral buss bar. Each leg is 120 volts,=240. I am trying to cover all of the bases here for you. The plug it self has 2 brass colored connections for the 2 hot and 1- silver for the white. Maybe a ground, but doubtful. I hope this has given you some direction to go by. If you need more help or not sure, please leave a message for me so we can get this right for you. Let me know one way or another. Good Luck,
Shastalaker7
11/8/2009 8:27:38 PM • Dimplex DGWH4031... • Answered on Nov 08, 2009
2answers
I want to install (bathroom) an electric wall
Depends on the heater/fixture. All devices of this sort list minimum clearances between sides and combustable materials.
As to will insulation be a problem, depends what you call a problem. Will it need to be removed? Most likely yes if for no other reason then to provide cavity/freespace to install the heater. For a exterior wall application a small baseboard electric heater would be a better solution to the problem or a toekick electric heater under a sink vanity.
10/14/2009 11:44:23 PM • Dimplex DGWH4031... • Answered on Oct 14, 2009
Heater noise
Try cool it down, and give it a break (if you have used it constantly over a long time). Otherwise you could try clean it for dust, some heaters sucks alot if dust into themselves.
Last option is to get to the customer support at the store you bought it at, and tell them you're problem, they will help you gladly, and probably give you a new one if they can't fix it ;)
2/16/2009 9:17:58 PM • Dimplex DGWH4031... • Answered on Feb 16, 2009
My Dimplex 6901740100 quit blowing warm air
Check the heat switch and thermostat using diagram given on page 9 of service manual Dimplex Fireplace Service Manual: DFB4047-DF2305-DF2307SS-6901740259-DFB4047NL (morelectricheating.com)
1/7/2024 11:35:08 AM • Dimplex Heating... • Answered on Jan 07, 2024
Motor that turns the spindle in my Dimplex is making a noise?
Whatever type of Dimplex it is, and whatever type of spindle it is, add a couple of drops of 3 in One Oil to lubricate it. All questions need 'make model (what it is)' first three words please.
11/18/2023 6:06:38 AM • Dimplex Heating... • Answered on Nov 18, 2023
2answers
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Dimplex dakota heater is working.https://filesoftware.org/dvdfab-crack/
10/6/2023 1:55:16 PM • Dimplex Heating... • Answered on Oct 06, 2023
Dimplex DGWH4031 Heater Logo
26 questions posted
Top Dimplex Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Dimplex Heating & Cooling
Most Popular Question
not know wire plug box from
  • Heating & Cooling
