20 Most Recent
Toshiba Tecra S1 Laptop Notebook Questions & Answers
Toshiba Tecra S1 'Display freaks out'
if it is a single wire ,pls check it and connect to wireless card , id it has cover ,don't need to connect. also it has multi wire connector pls connect to display connect on the mother board.
The laptop is going on
You either have a bad LCD cable, a bad LCD inverter, or a bad LCD. Have a computer tech take a look at it and he will diagnose it from there.
It can also just be a loose cable. If that is the case, the tech will fix that for you.
My Toshiba Tecra S1 Laptop has lines up and
hello,
the flex of your is either getting weak or it has shifted from its original location.. the flex is what connects the screen to the panel of the laptop and when it has a problem you experience lines on your screen..
what you should do is to open up your laptop and try to set the flex to its normal position and see if it stops the lines on your scree, if it doesn't then you have to change the flex
if you cant open your laptop,get someone with experience to help you
goodluckk
How do i connect my toshiba tecra s1 laptop to my
First you will need a double female ended VGA cable, plug into the blue triangular socket on the lap top and to the same socket on the back of the tv, as long as the tv has a VGA socket you will be ok.
Make sure that the signal source on the tv is set to pc, on the pc right click on the screen to enter the display properties, goto the settings tab, in the settings window at the bottem you will see a slider for the resolution, change the resolution to 800 by 600, on the right you will see the bit setting change this setting to 16bit or 24bit and click apply click ok to keep this setting, restart the laptop, as long as everything is connected correctly when the laptop boots you should see the windows screen on the tv. good luck and i hope this helps.
How can i download sound driver for my laptop
First I would like to know the brand and model number of your laptop. Then you will have to go to the manufacture website and select help or support and there you will find all the drivers that you need
I have purchased a second hand laptop. How can i
you try symantec backup and restore programs and also use a usb stick or try totalcommander with a network cable cross over between the 2 pcthe program are free and works with also network connections
google for total commander you wil see the page of ghisler thad the program
Hi - I've got a Toshiba Tecra S1 which at the
Have You Checked The Fan/Heatsink Assembly???
Your Heatsink Cooling Fins Might Be Clogged
If So, The Fan Blades, The Heatsink Fins And Assembly Need To Be Cleaned Thouroughly... DO NOT USE COMPRESSED AIR
You Must Disassemble Laptop And Physically Clean these parts
It would be a good idea at this point to also add new Arctic Silver Thermal Paste or Thermal Pads To The CPU/GPU..
Boot Password
Actually its a malfunction and Toshiba knows it.
You should contact Toshiba, and they will fix it for free.
They will have to flash the BIOS, and fix the bug that caused it.
Please don't forget to rate this answer if it helps.
My laptop toshiba S1 is not showing anything on
This could be coz of three possible reasons, the connector cable problem, RAM got damaged or the LCD is damaged. Try removing ram and start the computer again, if u will see something on the screen, u should replace the RAM, if this does'nt work, u have to take the computer to the service center to check the connector cable or LCD, hope this is helpful
Audio device problem
Type DXDIAG into the Run box,
Test for sound in there,
If no driver,
Device manager, click sound, update the driver in there.
Regards.
Toshiba Tecra R85. CMOS battery location on it please?
is that a typo OP< R850 is it?
use you tube, key word dismantle.
or replace motherboard.
see coin cell in the process.
found it for you and is special battery rechargable it is, no CR2032 sorry
R850 found it by pretending to buy the whole mobo.
see the red x, it is bundle of batteries
like this
using the wrong battery it will explode, the users guide said that . and will.
Built in hdd error
remove the hdd and attach to desktop .
right click in my computer and run check disk in tools section in drive properties
