20 Most Recent
Apple Mac mini Questions & Answers
Intermitant failure of the firewire port
It's quite possible you have a FireWire port with hardware problems. The fix is somewhat costly, because it requires a logic board replacement. You need to bring your machine in for service.
I get a blue screen whit a message. Or in other
Probably your internal HDD is bad.Try booting the system with Installation media and and check the HDD with disk util.if the hdd is not showing in disk util then the HDD is bad.Replace the HDD
Intel iMac: disk does not eject, does not mount, makes no noise
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Here are some steps I recommend you try to resolve the issue
with the disc not ejecting properly. Now you mentioned that you used the drutil tray open command- if that is correct, then for your Mac Mini, that will not work, because that command is for drives with trays only.
In your case, you have slot drive in your Mac Mini so try the command line that I have provided below. It is just a slight modification from what you stated you tried.
-EJECTING DISC USING TERMINAL-
From your Desktop:
•Click anywhere on a blank space on your desktop. Now you
should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities
from the
drop-down menu. This
will take you to your Utilities folder.
• Locate and open the Terminal application.
• At prompt, type: drutil eject and press the Return key on your keyboard
(NOTE: If you have a
CD/DVD drive with a tray, type: drutil
tray open press the Return key on your keyboard).
If that procedure with Terminal does not work, there are two applications that you can try:
Disk Utility- You open the application, select the affected disc or the optical drive in the left sidebar window. Then select eject from the top of the Disk Utility menu. See if that work.
iTunes- Simply open the application, and select the eject icon at the bottom of the window.
Last but not least, I did notice you did not mention that you try this procedure:
Reboot your Mac Mini.
As the Mac Mini boots up, hold down all mouse buttons and keep holding them down until (hopefully) the cd ejects.
I am not sure if you have done all of these processes for ejecting your disc, but again these steps were not mentioned in your initial inquiry.
Let me know if these additional steps have helped or if they are in fact redundant.
Regards,
-Mactechtrainer
How do I download?
1. Find a down loadable program on the internet.
2. Click it.
3. A box will open with 2 options. "Open with" and "Save File".
4. Select an option.
5. Locate the file if you saved it. It is usually in your "downloads" folder.
Good Luck.
www.cobaltflorida.com
Broken power button jack/plug on apple mini mac (post 2009 intel)
Not sure about schematics but here are a couple links to disassembly guides:
<http://www.applefritter.com/Mac_Mini_Take_Apart_Guide>
<http://www.r3uk.com/index.php/tech-tips/34-disassembly-guides/4-apple-mac-mini-model-a1170-disassembly-guide>
Also,
Check this site out <http://www.123macmini.com/news/story/316.html>
Good luck.
K.
Adding memory to my mac mini
You can buy memory and find out how much your mac mini can hold by going here http://www.crucial.com/ I would be able to do it for you but I don't know which model you have. As far as replacing the memory its not for the faint of heart but this tutorial will get you through http://www.methodshop.com/gadgets/tutorials/macmini-ram/index.shtml
Pc web cam on a mac
Macintosh (OS X) drivers for many PC web cams can be found at the following link:
http://webcam-osx.sourceforge.net/cameras/index.php
Hopefully yours is there.
Regards,
Cybernanga
My mac mini cd burner has stopped working
does it boot up at all if the osx is starting then it is, have u run out of space try getting external drive even dongle 8gb and tell itune to save to this see if thats the problenm the harddrives arnt big on those
actionman
