BIOS password ... simple, find and disconnect the motherboard battery. Wait 30 seconds and reconnect it. You will find it in one of the small compartments on the bottom, probably in with the memory.
Thanks for your question @ FixYa.com
You got 2 options:
1-Start the pc and when you see Windows Welcome screen / Login screen,
press ctrl>+alt>+del> keys twice and it'll show Classic Login
box. Now type "Administrator" (without quotes) in Username and leave
Password field blank. Now press Enter and you should be able to log in
Windows.
Now you can reset your account password from "Control Panel -> User
Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show
this in-built Administrator account in Login screen.
2-Some computer systems have a setting in the BIOS Setup to disable the
password. The BIOS Setup is accessed with the F1, F2 or DEL key during
boot up.
If you have forgotten your password, most systems have a jumper on the
motherboard that can be pulled off to clear the password. If there is no
jumper available, you can also remove the battery for 5 minutes to
clear CMOS.
If you need more help post back!
Thumbs and testimonial are welcome!
SOURCE: will removing the cmos battery help remove bios password
Yes, if you remove the cmos battery and have your PC unpluged wait 2-3 mins before reseting battery it should reset the bio's.
SOURCE: bios password
remove the bios battery from the laptop for about 30 minutes, when you put it back, you will not have the password anymore for bios, reset...
it can be upright or flat out, just check your and remove it.
SOURCE: forgot password for bios before windows
I had similar problem with an inspiron 1521. Click here to get the solution. Its easier than you think!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=320354292216&ssPageName=STRK:MEWA:IT&ih=011
SOURCE: forgot password and cant enter bios with out it
BIOS password is stored in c-mos battrey...A small battery in the motherboard.....if u take out the battery and put it again.....The password will b lost....and then it won't ask for bios password...
SOURCE: forgot my bios password please help benny
There are a number of reasons why we might set a password to protect
our BIOS from changes. The problem is that we only need to go in there
once in a blue moon, making the password easy to forget,
locking everyone out.
I had a situation many years ago where a colleague suggested the
purchase of a new motherboard because they couldn’t remember the
password. I got that little bit more frustrated with my job that day.
There are various options you can use to get back into your BIOS.
All of them reset the BIOS back to default values, so make sure you’ve
tried all of your regular passwords before attempting these methods. I
have tried to keep it brief…
Newer Computers: Most newer motherboards have a
jumper on them, which you can change the position of to reset the BIOS.
Find your motherboard manual or search for the motherboards model
number in Google. You want to find a diagram showing what and
where various components and jumpers are on the motherboard. The manual
should tell you which jumper needs to be changed.
Once you have changed the jumper, return the jumper back to its
original position while the machine is off. You don’t want it to keep
resetting itself. Turn on the machine and go into the BIOS. All options
will be open to you.
Older Computers: The quickest way to get into the
BIOS of an older computer that has been password protected is to remove
the battery. The battery keeps the system clock going. Once you remove
it, you can put it back in and start the computer.
When you start your computer, you will find your BIOS has been reset
to its default values. You are now able to change any settings you want.
General: Some motherboard manufacturers have a
secret password that will work, overwriting the password already
locking the computer. These are readily available online with a bit of
a search. I think this is becoming less common with time.
For more information on the methods above, tech-faq has a great article which goes more in depth.
