20 Most Recent
Samsung R540 Laptop Questions & Answers
I can't open short films
if you are using windows media player you are most likley tryinh to play a unsupported format. VLC media player plays just about every video format download and install that. then play your files with vlc media player by opening vlc then click the media tab the open media then locate your video and double click it
Samsung R540 boot usb
Do you wish to boot from a USB stick?
If so, press F2 upon booting.
Navigate to the 'boot' section
Find your USB device in the list, you are looking for USB hard disk or similar
Put it at the top of the list
Save, I believe with F4, then restart your PC
Similar to the above image.
Reset ram
are you sure its ram fault?is it beeping on start up?if so then replace ram.
some laptops shut off if the fan is not running and it gets hot.
clean fan out.
let me know if it still wont start.
Turns on shuts off
check its not over heating,,check fan is running.
if its not you will have to clean it out.
some laptops wont start if fan is not able to spin.
if its not that please get back to me.
also check power unit pluse see if it will start with the battery out,,some will run with out it.
RED LINE ON BOTTOM OF SCREEN
If its your GPS screen, then get it replaced. LCD/ led screens are horribly expensive to fix. A replacement is much cheaper and wuicker
