Look at the red indicator arrow when you hit the foot pedal. If it lights up, the motor should run. If not, inspect the splices under the top cover on the shaft. They will stop the motor if corroded or burnt.
1. possibly a broken connection to the motor where the propeller is located. 2. Also could be a bad motor. 3. Look for a fuse location for a possible blown fuse to the motor. 4. motor brushes could be the problem.
If this is a foot control model, try cleaning the connection where it plugs up. I have cleaned mine but I still have to fidget with it every time to get it to work right.
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
