SOURCE: Frigidaire air conditioner # FAC127P1A1
You can view the manual directly on Frigidaire's website: Use and Care Manual. Look on page 11, under "Care and cleaning". Note that the link is to an Adobe PDF document.
Testimonial: "Thank you, Thank you, Thank you!! Just what I needed!"
SOURCE: I have Frigidaire Thru-the-Wall electronic
As the smell comes only when the Air conditioner is on. The problem is due to the refrigerant inside.May be due to long usage the refrigerant as lost its property.Please drain out all the refrigerant and refill it.You wont get the foul smell problem.
Thank You
SOURCE: The interior of the air conditioner behind the
Remove the front of he unit, as if you're going to clean the filter. That will give you access to what you need to clean. Use warm water and dish washing liquid to wipe off the mildew. Rinse with clear water and a sponge, dry thoroughly and replace the filter and the front of the unit.
NOTE: Before attempting any of the above. Turn the unit OFF & Unplug it.
