20 Most Recent Frigidaire FAC084N7A Air Conditioner Questions & Answers
My little Frigidaire (5 or 6k btu) beeps intermittently and is really annoying. I never know whenn it's going to happen.
Frigidaire... | Answered on Jul 17, 2015
Good Morning Friend,
I understand you are looking for the manual to your Frigidaire air conditioner, model# FAC084N7A. I also see you want to know the BTU rating. Your air conditioner is rated 800-BTU. I have attached the manual below. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
Frigidaire... | Answered on Jul 11, 2014
If you have a unit that has stopped cooling in a couple of days... tkae it back and get another one...you got a lemon...
do not mess with it or tear it apart... just put it back in the box and return it for another one...
heatman101
Frigidaire... | Answered on Aug 31, 2010
Clean floor of unit under coils so front coil water can drain under the coils to the back drain.
Don't forget to tilt them unit a bit to the back to allow the water to drain towards the back.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Frigidaire... | Answered on Aug 23, 2010
It needs cleaning ,if it is a window unit,remove it from the window,from it`s shell,and take it out side and wash it out,be careful not to bend over the fins on the evaporator,and the condenser with the water hose.If this does not help,then it needs some freon.
Frigidaire... | Answered on May 31, 2010
It's obvious to me that your motor 'quit' turning because of a lack of lubrication.
You have one 'slight' chance here - and that depends on whether or not you are able to take a drill and 'drill' a small hole on top of the bearing case (which encases the bearing).
On most motors you can do this quite easily. Just look on the end of the motor (where the shaft comes out of the motor) and you should see the bearing encasement (on some motors this is internal and you won't be able to do this). - but in any case if you can - 'just drill a small hole at the top of the encasement and then take a oil bottle, one of those plastic ones with the long slender tube - and oil the motor. I've done this many times in the past and more times than not your fan motor will run normally for quite some time.
Note: you must understand though - that the damage already done to the motor 'might' cause this manuver to be un-sucessful, i.e. the motor may run and not make noise but will heat up and go off - or it may still make the grinding noise and also heat up and go off.
But, you do have a chance this way.
If this doesn't work - the only thing to do is to replace the motor.
Note: I've never took one of these motors apart and tried to oil the bearings as you suggested - mainly because the chance of success - versus the "time and trouble" to do so is very slim.
good luck!
Frigidaire... | Answered on May 16, 2010
There are a few checks that could be done, i.e. you could 'ohm the compressor out' to see if it had a 'short, or its windings are 'opened.'
Or - if there was a valve on the AC - you could tell if the system was holding it's refrigerant or not - you could also visually examine both coils to see if they were 'clean.'
But to 'make sure' the AC is operating 'correctly' will require all the components to be working - including the fan motor.
Frigidaire... | Answered on May 15, 2010
Does it get cold? You can try cleaning the fins-both inside and outside, with windex. Smoling & cooking will create a sticky deposit that will make dist that gets through the filter stick and it won't cool properly.
If it doesn.t get cold any more, try replacing the starting capacitor. About $5. If that doesn't take care of it, just replace the unit. They are cheap enough these days, that you can replace a unit with a more energy efficient unit for the same cost or less as a repair would cost.
Frigidaire... | Answered on May 26, 2009
yes, but when it is running, does it also turn off??
Frigidaire... | Answered on Jul 26, 2019
Could have clipped the low voltage wire outside with a weed wacker, could have blown out the run capacitor or lost a major component! If the unit is buzzing when you turn it on but nothing's running (compressor or fan)then you have a failed run capacitor! The list of things it could be are endless without more info
Frigidaire... | Answered on Jul 13, 2019
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Frigidaire... | Answered on Apr 08, 2019
Frigidaire FAC084N7A Air Conditioner Logo
11 questions posted
Top Frigidaire Heating & Cooling Experts
Donni Steen
Bill Long
Pete Norton
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Heating & Cooling
Most Popular Question
leak water in front air
  • Heating & Cooling
