20 Most Recent Frigidaire FAC127S1A Air Conditioner Questions & Answers
Friedrich window units should reset by pressing both the up & down temp buttons simultaneously. Had this issue for a while until I finally called the help center. For some reason couldn't find this info anywhere online. Hope this helps !
Frigidaire... | Answered on Sep 25, 2017
Usually, recharging the compressor on a regular basis is not required. Does it seem like yours may need recharging? There are other things that can mimic low refrigerant gas in the compressor.
1. The filter needs cleaning or replacing.
2. The cooling coils and/or the cooling fins may need cleaning.
3. Unit is in a window that gets direct sunlight for 6 hours or more.
Recharging the compressor (depending on where you live) properly to EPA Standards can cost $100.00 or more.
Hope this helped you. Please let me know. Thanks
Frigidaire... | Answered on Jun 27, 2015
Download manual from here: http://www.searspartsdirect.com/partsdirect/user-manuals/FAC127P1A1-Frigidaire-Parts-Room-air-conditioner-Parts-manual
Frigidaire... | Answered on Mar 06, 2015
scrap it, buy a samsung
Frigidaire... | Answered on Jan 06, 2015
Good Morning Friend,
I understand you want to know how to clean the condensation drain on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, and beginning to leak from the front. The drain hole is located beneath the compressor. You would have to get underneath that to clean the drain. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 10, 2014
I understand you want to know where the drain hole is on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, instead of draining. The drain hole is located beneath the compressor. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. Hope this is helpful.
-Best Regards-
WP
Hi Brittany - When was the last time the filter was clean? Restricted air flow from dirty air filter can caused air conditioner to turn on and off rapidly. Make sure there is nothing blocking the airflow to the unit like blinds, drapes, furniture, etc which could restrict air distribution. Outside condenser coil could possibly be blocked or dirty. Confirm that the condenser coil is clean and not restricted by any trees, bushes, etc. Verify that the plug is not damaged and try resetting the unit. If any proves to be ineffective, contact a professional to move forward accurately.
Frigidaire... | Answered on Oct 18, 2012
Hello Ramona - Could the error code possibly be S or ES? If so, typically that indicates that there is a problem with the evaporator sensor. I would recommend contacting a professional to accurately diagnose and repair the air conditioner.
Frigidaire... | Answered on Oct 04, 2012
Some units the cord is actually detachable, if you don't think this one is, contact your manufacturer to see if they offer a replacement cord that you can purchase. Some do, some don't.
Frigidaire... | Answered on Sep 07, 2012
Does this unit have a remote? If so, try to use it, does it work then? If not, then the control board is most likely your culprit. If it does work, then possibly a button on the control panel is faulty.
Frigidaire... | Answered on Jul 24, 2012
Frigidaire FAC127S1A Air Conditioner Logo
38 questions posted
Top Frigidaire Heating & Cooling Experts
Donni Steen
Bill Long
Pete Norton
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Heating & Cooling
Most Popular Question
error codes
  • Heating & Cooling
