SOURCE: Disney 13' Princess tv
You've tried all the codes for your TV, but you still cannot get the remote control to operate your TV.
Hope this helps
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
Direct Code Entry
To program your universal remote to control your components
using the Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you want the remote to
control.
2. Locate the enclosed Code Lists. Find the list for the
component you wish to program. Find your component's
brand. You will see a listing of four-digit codes for each
brand. If your brand isn't listed, use one of the Code Search
methods to program the remote control. (Refer to pages 3
and 4 for Manual and Auto Code Search methods.)
3. Press and hold the component key (TV,
VCR•DVD, SAT•CBL) you wish to
program. The illuminated ON•OFF key
turns on and remains on. If you release
the component key at any time during the Direct Code
Entry procedure, the illuminated ON•OFF key blinks four
times, and the process is exited.
4. While holding down the component key, consult the
Code Lists for the four-digit code that corresponds to your
component's brand and use the number keys (0-9) on the
keypad to enter it. While you are pressing the numbers, the
illuminated ON•OFF key turns off.
5. After the fourth number is entered, the illuminated ON•OFF
key turns on. At this time, release the component key. If the
illuminated ON•OFF key turns off, you have entered a valid
code and have followed the correct procedure for Direct
Code Entry.
If you enter a code number that is not in the Code Lists or
you do not follow all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks four times when the
component key is released. This is an indication that a
programming error has occurred. In that case, repeat the
Direct Code Entry process from step 3.
Tip: Throughout the programming of each key, be sure to keep the
remote pointed at the IR sensor of the component you are currently
programming the remote to control.
6. To confirm that the component key is programmed with
the correct code for maximum functionality, test the
component. Attempt to control a variety of the component's
functions with the remote. If some of the features of your
components do not work, try programming the remote with
a different code in the list until you find the code that allows
the remote to control the majority of your component's
functions. Different codes can provide different levels of
functionality.
OK.
1* Manually turn on the component you want the remote to
control
2* Locate the enclosed Code Lists. Find the list for the
3* Press and hold the component key (TV,
4* While holding down the component key, consult the
5* After the fourth number is entered, the illuminated ON•OFF
Code Entry
6* To confirm that the component key is programmed with
functionality.
You haven't asked the codes. If you may have given the Brand name of your TV to which this remote control should be synchronised, I may have give you the codes also.
If you want anymore assistance from me. feel free to get me by FixYa. OK.
control.
Code Entry
functionality
[1] Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
[2] Enter the 5-digit code for your DIRECTV Receiver
[3] Power on the DIRECTV Receiver
[4] Move the slide switch to DIRECTV icon
[5] Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
[6] Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
[7] Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
OK.
