Mitsubishi WS-65857 65" Rear Projection Television Logo
Posted on Aug 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fixed green light have audio but no video
Ws 65869 fixed green light have audio but no video am getting only a green screen or blue screen depending on input selected. get full color when I select the menu. have audio. cable repairman says cable is fine, tv isn't accepting input. this there a part I can buy and replace by myself?
Anonymous
Level 3:
Genius:
  • Master 2,920 Answers
  • Posted on Aug 28, 2008
Anonymous
Master
Level 3:
Genius:
Answers
2920
Questions
0
Helped
935010
Points
7574
It sounds like the tuner went out,you would have to know how to solder and remove the old tuner to be able to do it yourself
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
2helpful
Mitsubishi WS-65869 65" blue color problem
Yes, you need to replace the convergence output amplifier IC's. They can be ordered on line. After removing the back you must remove the circuit board which houses the amps. Then desolder them and install the replacemnts. If you are extremely lucky there won't be any re-alignment issues with the new amps. Then you should be good to go.
MITS WS-65869 The green CRT is creating a warped image.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
Green screen
If you are using the component video input change the input setting of the DTV input from RGB to Y, Pb,Pr also make sure the DVR's setting is 1080i output. this set can only except 480i, 480p and 1080i only. also make sure you have the green wire to the green input the red to the red input (some have mistaken the red audio for the red video) and the blue to the blue input.
2answers
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Mitsubishi WS-48613 No Video
If you have no video and audio then IC9c25 on Sig. Bd.
Mitsubishi WS-65905 DTV is green
A compatibility issue rears its ugly head. The format that was to be back then has changed slightly over the years and this is what it's come to...Sorry...accordianman
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
