SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
SOURCE: Hotpoint Aquarius DWF32 dishwasher pump replacing
its easy just uninstall the dishwasher and flip it on its back .i know it sucks but once the unit is out its no problem.
SOURCE: Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
SOURCE: Hotpoint Aquarius SDW60 Dishwasher
i have had this dishwasher sdw60 for 18 months and it just keeps beeping, i have cleaned it ,turned it off at the mains it just dont wont to work. please help.
SOURCE: My hotpoint Aquarius Dishwasher starts up bu only
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
