If your dryer is running but you have no heat being produced from the unit this could be caused by several reasons. In your unit there are are thermistors which allow the unit to run and act as safety devices so that the unit does not overheat and cause a fire or overheat causeing extensive damage to the unit. Your unit also has a hi limit and a low limit thermistor in it as well which tell the unit to shut the heater off due to it being to hot or turn the heater on due to it not being hot enough. In order to test these thermistors you would perform a continuity test on them using a multimeter and any that were to fail you would replace. You can also perform this same continuity test on the heater as well to assure the heater is functioning properly as well. If you are able to produce your model number I most likely will be able to find your schematic to your unit showing you where the thermistors are that you would test in the unit. Also if you have any other questions message me those back as well.I await your reply Thanks Rick
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
