Yamaha HTR-5650 Receiver Logo
Posted on Aug 25, 2008
No surround sound
My probllem is i cant turn the rear volume speakers up there is no sound from right or left rear speakers what do i do?
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 25, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
3078
Points
13
If the unit has no digital dvd 5,1 input it will not play 5.1 output, unless the unit is switched into a virtual surround mode(theatre/etc) mode try with a new dvd film with a digital glassfiber cabel if it shows 5.1 on the display of the receiver. if it shows 5.1 digital surround than the end stage of your surround is blown and needs to be replaced
pauliesbouth
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Unable to connect surround sound with a stero player
There is a obvious difficulty here. If you have a stereo receiver then it can't produce surround sound. You must have a surround sound receiver to present true surround sound. If you already do have that then on the back of your Phillips set there are audio outputs. The left and right audio out will be decoded in your surround sound receiver and they will automatically play from your speakers. You should have seven speakers, center channel, left and right front speakers, left and right rear speakers and left and right mid or side speakers. A sub-woofer would be nice too. Best bet is to speak with the store you purchased the set from. They will have that information.
Zashiban
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
2helpful
3answers
X-540 speakers no sound rear speakers
rear speakers are not designed to put out the same output as fronts. They are for supplemental sound only, to make it seem like there's something happening behind you.
Center, and rear surround speakers
Sounds like the rear volume is just turned down. Cant be the amp if the front and subs are working
Speakers stopped working.
More than likely you have blown outputs, as the sound you hear when you touch the leads to the terminals is the DC offset of the power supply being routed through your speakers...accordianman
How do i hook up Altec Lansing AVS500 speakers to my computer
Hello sweetnikki1,
The Altec Lansing AVS500 are 4.1 channel speakers, meaning 4 speakers (front, rear and 2 satellites) and a subwoofer.
1. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the satellite cords are similarly color coded. The output from the sub to the front right satellite is a heavy-duty cable that immediately stands out from the rest. This cable is thicker because the right front speaker has most of the system controls on it: power, volume, and surround volume. If you do not have a surround sound card, make sure you obtain the proper adapter or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, on the left side are the sub level control, the AC jack, satellite outs, and a sound mode switch. With this switch you decide between Gaming and Stereo. In Stereo mode, the normal stereo signal is sent to both the fronts and the rears. In Gaming mode, the speakers use the four-channel signal from your soundcard. Hence if you just hav the regular sound card, do not connect the satellite speakers and use Stereo mode.
3. You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
Hope this helps..
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further, if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FixYa! rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
4answers
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
