20 Most Recent Sony STR-DE635 Receiver Questions & Answers
0answers
0answers
Left surround speaker outputs not working
Might be a bad speaker relay.
7/3/2013 2:58:16 PM • Sony STR-DE635... • Answered on Jul 03, 2013
Where do i find an A/B speaker switch
It's probably not the switch. These models have a common problem with the solder connections between the switch pcb and display pcb going bad. You need to resolder these connections, and your problem should be solved.
6/18/2013 7:42:22 PM • Sony STR-DE635... • Answered on Jun 18, 2013
2answers
WHEN TO TURN SONY STR-DE635 ON AND NO AUDIO OUPUT
Maybe the Preamp driver IC, looks like a car audio ic on the main board.Often with age the heat generated by the ic will destroy the solder.Makes it look like lava rock in bar-b-que grill. Whichcauses an open circuit in the preamp driver to the audio powerstage.Simply resolder them, most often restores audio. Should havea bottom removalble cover.If not, a fuse normally blows if ic or channel is shorted. Check ifdisplay will say Power off, Protect, etc. That means there is a problem with a channel. Most Sony receivers use darlington transistors, they short easily !! I am an old school component level service tech, I think I do have a schematic for this model and many others.
1/17/2012 6:30:22 AM • Sony STR-DE635... • Answered on Jan 17, 2012
0answers
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
4/22/2011 5:24:59 AM • Sony STR-DE635... • Answered on Apr 22, 2011
The protector keeps coming on every so often after
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
1/10/2010 12:41:29 AM • Sony STR-DE635... • Answered on Jan 10, 2010
When i turn on the receiver it clicks into
you need to change audio amplifiers IC´s
10/27/2009 2:13:02 PM • Sony STR-DE635... • Answered on Oct 27, 2009
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
5/27/2009 7:41:20 PM • Sony STR-DE635... • Answered on May 27, 2009
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
5/20/2009 7:10:53 PM • Sony STR-DE635... • Answered on May 20, 2009
36 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
find b speaker switch
  • Audio Players & Recorders
