dear some htc mobiles like htc diamond are designed for specific languages! if you install a software for english language some other software may not be work! so i suggested you to use your mobile wid the same language cilck on yes if you like it!
Hi Akila,
In normal case to change the language of the operating system press HOME > MENU, then tap Settings > Locale & text > Select Locale and then select the language you want to use.
And
If you have installed 'rom' by selecting a language after purchase then the only way to change it is to install a new rom with the language you want. The issue is that Windows Mobile does not allow the user to change the language of the rom once it is installed.
You need to contact HTC to ask them for a replacement rom that is in English.
Hope this helps,
Please leave a comment and rate if the solution was helpful, thanks!
Hi there!
You'll need to follow this steps to change the language of your HTC TyTN II
<p>1. Make sure you install Microsoft ActiveSync in your computer. Do a first time sync between your phone and the computer.</p><p>
2. Disable any screensaver and/or hibernation in your computer.</p><p>
3. Sync and again and flash with the HardSPL rom from OliNex. You can find this HardSPL software from here >> http://wiki.xda-developers.com/uploads/Unsigned_HardSPL_for_Blackstone_OliNex.zip
The flashing completes in under 2 minutes.</p><p>
4. Reboot device. TouchFlo3D will launch into the native language the device originally came in. The new rom now enables you to flash other language roms, even official ones from HTC, bypassing licensing and verification checks (of course you should have the relevant ROM).</p><p>
5. Finally, flash again with the newset WWE (World Wide English ROM. You can download the official English ROM here: http://www.htc.com/hk-en/supportdownload.aspx?p_id=13&cat=2&dl_id=287</p><p>
6. Device reboots in english, or the language of the ROM you flashed.</p>
Take note that by doing this, the warranty of your phone will be voided.
Hope this helps
i have this problem is not change language for german to english please send me rom windows mobile english for htc p4350 is not quiet problem please contact me : [email protected] or send me link for download software to formating mobile please kontakt me
u need to go to start>settings>system>regional settings andthen set ur device language to english if u want to make it completeenglish OS is that u mean ? then pls download updated English ROM fromwww.htc.com and install it as directed
i can help u more in this if u want pls rate me fixya if i solved ur problem
In order to change the language completely, you will need to flash a new ROM to the phone. This is the entire Operating System, Drivers, and other needed software for the phone to operate.
The best place for more information on doing this can be found at the following link:
They are very helpful there, and can point you in the right direction. Just remember, nobody there gets paid, so you need to be polite, and patient, but usually it will not take too long to get good answers.
