20 Most Recent
HTC TyTN II Smartphone Questions & Answers
Track lost HTC Diamond
Is your company on exchange 2007? and is your phone sync'd to it wirelessly?
You can allways deploy a GPS tracking tool to the phone if it hasn't been wiped.
I would suggest a tool that doesn't have much of a setup required and can be just "ran/installed"
My htc tytn ii stays on align screen after hard reset
Have you completed the alignment procedure? The phone will not let you progress until alignment is complete.
Once complete, click "OK" in the top right corner to exit the screen.
If this has fixed your problem then please take a moment to rate my answer, if not then please give more detail about what's happening and I'll try to assist you further. I don't have your exact model, but have owned a few other HTC models using both Windows Mobile (like yours) and Android operating systems so I'm confident that if the problem has a fix I can help you to find it..
I tried everything but cant
Skype is not designed for HTC TyTN II.
I have, however, forced installation for a newer model, and it succeeded, but is SLOW and I do not recommend it.
TronE
How to solve no signal problem on htc 8525?
I'm using HTC TyTN II with Windows Mobile 6.1 as OS. My problem is my phone keep loosing network signal and occasionally when it get the signal, I can't make a phone call. The signal is there, but when I make a phone call, it will disconnected at once.
Sim card slot stuck
1) taken apart and rebuilt cellphones and 2) dealt with hundreds of malfunctioning phones that didn't read SIM's, I'll give you some ACTUAL help.1) remove the SIM and check for any missing pins in the slot. You can only see the first row of pins on the N1, but that's all you can see without taking the thing apart again. You should see 4 pins, but the one closest to the notched corner of the SIM doesn't really do anything.2) If everything looks okay, reinsert the SIM, along with a couple pieces of paper. The idea is to press the SIM into the contacts in case the fit isn't as tight as before.If you either see damaged pins in step 1 or step 2 didn't work, take it back to the repair guy. He broke it, he's obligated to fix it.Auto Accessories
How do i insert sim card
In the past, some HTC devices have been affected by problems with touchscreen alignment, but you shouldn't have any problems with the TyTN II in this department. The 240 x 320 display is clear and bright and also seems not to suffer from yellow colour cast that has been common on earlier devices.
The keyboard has a nice positive action to it and works extremely well. It's virtually identical to the HTC Herald, and very similar to the HTC TyTN. Holding the device in both hands it's easy to type at a fair rate using just your thumbs.
Finally, to insert a SIM card you have to slide the keyboard open and then look on the rear of the screen. Under a flap you'll find the SIM card slot.
Car Tuning
