SOURCE: player won't play any disks only says CANNOT LOAD DISK
change the way you connect the dvd player to your tv
SOURCE: Dawoo DVD Player showing No Disk error
you have dirty lens, try to cleaning with 100% cotton buds. or you have damage laser eye, or broken flex ribbon wire, but first you have to do is to cleaning the lens with cotton buds.. if not reading after you clean the lens! change the laser eye and flex ribbon wire.
Open unit and blow off carefully on laser eye with dust can if not there is a good chance your laser and or spindle motor in laser assembly is bad .Easy to change out .part # 8-820-237-06 (comes with spindel motor) at www.sony.com in parts/acess section ..If you do decide to change yourself make sure you unsolder small dot of solder on laser before install ..This is shipped soldered for static reasons..goodluck
SOURCE: DVP-NS50P will not load DVD
the lense could be only dirty, try cleaning it first. i suggest do a manual cleaning if you can. open the top cover of the unit, remove the disk retainer and you will find the lense somewhere in the middle. use a cotton bud, use a little of alcohol, dampen a little only and wipe the lense in circular motion. then use new dry bud to dry it.
SOURCE: DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
If still persists, its time for your device to get serviced.
