This link may help you change Eureka Altima Upright Vacuum's belt.
http://www.ehow.com/info_8608139_eureka-altima-2961avz-vacuum-maintenance.html
SOURCE: How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
SOURCE: Looking for the instruction manual for the Eureka
Go to http://www.eureka.com/service/manuals/80244.pdf this is a direct link to the owners guide for your model or you can call customer service at 800-282-2886 and request a hard copy
SOURCE: What belt do I use for the Eureka Altima 2961?
Part number is 61120C according to the user manual.
http://www.eureka.com/servlet/FindOwnersGuide
Hope this helps.
SOURCE: How do I change the belt on Eureka Altima 12 v
Here is
a link to the owners manual which has instructions and a link to the
belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
SOURCE: how to change belt in eureka altima vacuum
Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
