I hope a way to delete this code from the screen
I waited for 20 minutes and stopped flashing screen
Will not disappear
Press any buttons after the screen has stopped flashing
please perform a factory reset on your machine and check that all keys function once this has been done. Then, you can attempt to start your machine again. If the keys don't function after the reset, then you'll need to schedule a repair for those. Thank you.
You have a needle in your F63 Treadmill? This is why we ask for full;
make model (what is is) in all questions. The Search query will be that and the word 'manual'.
PDF
F63. -3-. WARNING - Read all instructions before using this appliance. DANGER - To reduce the risk of electric shock disconnect your Sole treadmill from the.
PDF
The F63 / F65 have ten built-in programs: one Manual program (PO. P1-P5),. U1 & U2) and two Heart Rate Control programs (H1 & H2). SPEED. INCLINE. P1. P2.
Miele washing machine error code f63F63 malfunction: too much foam
If so, there is too much foam in the drum and you may have used too much detergent.Jul 15, 2020
Roger
Depending on the model number - (guessing its a W48XX series) F63 is a water path fault - This is the control unit that directs the water flow to the proper path (pre-wash, detergent, fabric softener ect..... ) Sometimes and audible clicking can be heard when this unit fails as it trying to switch to the proper path as per the program being ran.
It sounds like you have a blown motor controller. If your machine is older than 5 years then that's pretty normal for sole. Their belts don't last very long and they cause stress on the controller. You'll have to replace the motor controller and the walking belt.
