1995 Dodge Intrepid Logo
Posted on Jun 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1995 dodge intrepid new fuel pump and coil wont start no fuel comming up and fire wont start.car was running ok stop and never started agian.new fuel pump and coil after it wouldnt start
Anonymous
Level 2:
New Friend:
  • Expert 83 Answers
  • Posted on Jun 16, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
83
Questions
0
Helped
32131
Points
233
Your fuel filter is probably clogged. Try replacing it and go from there.
2000 dodge intrepid wont stay running
Have fuel pressure tested in both situations. I've seen fuel pumps quit once they get heated up, then when they cool, pump again. Perhaps try WD40 sprayed in to throttle body inlet when no start, and that will tell you if it's a fuel delivery problem. Just remove air cleaner intake hose at front of throttle body, and open throttle and spray for a second or 2 then try to start. If it fires up and runs for a second or 2, then it's a lack of fuel issue.
1994 dodge intrepid wont start
did you check the gas filter or fuel pump? That would be my first thing before all the other stuff you did. make sure it is getting fuel.
95 Dodge intrepid wants to turn over but wont. power to car is fine.
There is a number of things that this could be, bad rotor in the distributor, loose wire in distributor, coil is going bad, timing is off, coil wire is working right, out of gas, bad fuel pump. all i can say is have fun. start with the cheapest and easiest to fix and go from there.
2answers
1999 Dodge Intrepid 2.7L Replaced starter,
If there isn't much pressure, cycle the ignition without turning the engine over and try again. If it is still weak, you may need a new fuel filter. If it is strong, you may have dirty or clogged fuel injectors.
It may be spark, but I'm inclined to think it is fuel related.
Good luck, and keep us in the loop!
JT
2answers
I have a 1995 intrepid it doesn´t turns on and we change change the computer what could it be?
If the starter is good and you have fuel at the injector and spark at the plugs at the proper time it should start.
The computer is only there to make everything run good and could be bad but the engine would still run.... badly but still run.
3 things to look for
1--- fuel
2--- spark to the plug
3--- make sure timming is ok.
1helpful
2answers
Chrysler wont start
I CHANGE CAM AND CRANK SENSOR,FUEL PUMP,COMPUTER BRAIN BOX AND COIL PACK STILL GETTING NO FIRE UNLESS I JUMP A FIRE WIRE FROM BATTERY
2answers
Fuel pump
tell you where i would start first it sounds as though you have more then one problem ak first check your map senser,fuel filter & also look around the wiring harness focos on any area where there is movement it really sounds as though you have an electrical problem also check the harness where it goes through the fire wall (shake the harness while watching your lights see if they flicker) if this doesnt help narrow it please contact me via E-MAIL and i will see if i can help you [email protected]
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
