NewAir AC-12000E Portable Air Conditioner Logo
Posted on Jun 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Window kit dimentions i have a window 18 inch wide
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
505
Points
Can we use the fan on kenmore portable air conditioner
without the hose being hooked up 12000 btu model 12935712
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Jun 13, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2105199
Points
14643
The portable AC units generally have a customizable, exhaust hose window, termination kit that comes with the unit.. In other words it can be cut to fit. The one that comes with the unit will fit casement windows, as well as sash windows.
To further assist you, I have included a link to the Owner's/Installation Manual for the model you referenced. You may download and print it if you like.
http://www.air-conditioner-home.com/manuals/ac-12000.pdf
Hope this helped you. Please let me know. Thanks.
What is the cu ft of Model FRT21IL4FW3 Freezer space?
Easiest solution is to measure the inside dimensions in inches, tall, width and depth. Then multiply the three dimensions t x w x d = cubic inches. To get cubic feet then divide the above answer by 1728 and the result is cubic feet..
For instance if the fridge is 60 inches tall x 24 inches wide x 18 inches deep; the answer is 60 x 24 x 18 = 25,929 cubic inches... 25,920 divided by 1728 = 15 cubic feet.
2answers
I desperately need a 400 mm wide dishwasher - is there any out there?
NO i dont believe so the 2 width of the dishwashers made are
18 inches...450 mm
24 inches..600mm
a 16 inch...400 mm is not one know to be made
Aug 28, 2011 • Dishwashers
1helpful
My window is only 18-19" wide. I need to know the
You can find the information you're looking for, as well as the Owner's Manual and Installation Guide at the following link.
http://www.frigidaire.com/products/air-conditioners-dehumidifiers/window-air-conditioners/fra052xt7
I have difficulty with regular jams regardless of brad length. Thoughts?
Depending on type of work/wood the finer the nail, results in increased jams. Eighteen gauge and finer experience more jams than say 15 gauge. Fine gauge nails also suffer from square cut tip. I believe that if the nails were pointed (like Senco nails ) they would more likely drive true. Jaming can be decreased by selecting the correct nailer for particular work. Dimentional lumber and hardwoods tend to increase problems compared to quality plywood or non wood trim materials. If you experience jaming with any type of wood then time to look at driver for possible problem. Check driver for bent or worn tip. Driver blade can be dressed square on grinder. Some drivers have a slight angle/taper ground into tip on the side that faces the rails. This taper continues up the blade about 1/2 inch. The taper will prevent the driver from hitting the second nail. On really hard woods, try drilling a fine pilot hole to produce best results. Good luck
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
1helpful
Top NewAir Heating & Cooling Experts
Paul Carew
john h
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
