Televison & Video Logo
Posted on Aug 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sanyo tv was hit by a power surge.now it dosnt turn on. i have a 27 inch sanyo tv
Jesse Hassan
Level 2:
  • Expert 54 Answers
  • Posted on Aug 19, 2008
Jesse  Hassan
Expert
Level 2:
Answers
54
Questions
Helped
16526
Points
190
You have a power supply issue on the main board of your set. This is not an easy fix for a home owner, Your best bet is to call a service shop and get a price quote. Tearing into tv's is very dangerous! High voltage is present even when unplugged! Good luck!
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Where is the reset button
Sanyo Service Menu - Factory-Reset.com
factory-reset.com/wiki/Sanyo_Service_Menu
Jump to Sanyo TV Service Menu Method 2 - Unplug the power cable. Press and hold the {VOL -} button on the TV while plugging the power cable back ...
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... I have a Sanyo TV, I accidentally hit the reset button twice. I ...
Aug 6, 2012
36 inch sanyo tv won't change off video 2?
Apr 17, 2010
I accidentally hit the 'reset' button the remote of my sanyo tv ...
Jan 6, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
Sanyo plasma tv vs power surge
Oh dear, the line out section has got hit and this might require attention by a qualified service technician.
Panasonic 27 in TV
Power surges will attack every board in the unit, it is possible that they discovered that more boards were affected then could be changed for a reasonable cost. These tv's are not component level repair, but board level repair. There is no easy or good solution when a set has been severely damaged by a power surge. The best answer is usually to replace the tv. Also power surges are covered under most homeowners insurance.
Sony BRAVIA 32 inch
I had the same problem with a old Sony TV.
To find out if the problem is temporary
  1. Turn off the television.
IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
If the light is still flashing the tv has stop working and you will need to buy a new one.
2answers
Picture tube
no you have no vertical bad chip ic
2answers
SANYO MODEL #DS13204, DS19204, DS25204
Do you have a user manual? Look for the instruction how to reset your tv. Try to plug your tv to other outlet, Chech the AC voltage if compatible to your tv. If dosnt work you need a repairman to fix it.
Sanyo TV stretches outwards and shakes
If the picture is closing (top to bottom) and goes back to normal when you hit it you probably have a bad solder connection on IC501 (location number) the vertical deflection IC on a metal heat sink. If you mean outwards as in side to side as it looks in the picture, I don't know specifically where to solder but get a magnifying glass and look for suspected bad solder connections. Look for the word width if it is there. It is good that you a confident in soldering.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
