20 Most Recent Sylvania 6427TE 27" TV Questions & Answers
Cannot get on slotomania on facebook
Sylvania 6427TE... | Answered on Mar 15, 2017
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Sylvania 6427TE... | Answered on Feb 02, 2016
Codes are stored in the (universal) remote. You can use its code search (or equivalent) feature to find a code that will enable some or all functions of your Sylvania TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Sylvania 6427TE... | Answered on Jan 19, 2016
If no channels are detected by scanning, you should check for a good antenna or cable connection at the rear, then scan again.
Sylvania 6427TE... | Answered on Dec 22, 2015
Here are the Sylvania codes
SYLVANIA 004,008,009,062,068,069,074,075,077,155,161,163,189,198
Sylvania 6427TE... | Answered on Oct 02, 2015
On older tv sets there are limited inputs...one for video and one for audio..
Find the white output hole for video on the back and run the cable to the set, and as for the audio there will be 2 red output holes (left and right on your dvd/vcr combo unit) this will use a special cable you can buy at radio shack that converts the left and right to just one output(it's like a "y" looking chord. it will still work if you just use one audio chord "out" from the dvd/,vcr unit but you will be hearing only one side of the "Stereo"
plug these into the back of your old set the white is for video and the red is for audio.
Sylvania 6427TE... | Answered on Sep 15, 2014
Let the channel scan complete fully. This just needs to be done once for antenna channels and once if you use cable. Should take about 5 minutes to complete, but if u must interrupt or exit, press menu, or power to turn off TV. Make sure the tv's tuner setting is set appropriately for either cable or air (antenna), depending on your way of receiving channels, so it scans and finds properly.
Sylvania 6427TE... | Answered on Sep 12, 2014
Check the horizontal & vertical scanning section circuit. What else to do?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sylvania 6427TE... | Answered on Aug 30, 2014
Sylvania 6427TE... | Answered on Aug 03, 2014
Check the input selection settings to TV. Refer its user manual for details.
Sylvania 6427TE... | Answered on May 08, 2014
0601 0166 0460 0338. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
Try this link too
I have the same problem with a 6420ff sylvania tv with a xbox 360. I plug the red white yellow into the front of the tv and it wont come on.
Sylvania 6427TE... | Answered on Apr 13, 2014
Adjust the tint or hue in some models
Sylvania 6427TE... | Answered on Jan 18, 2014
Use the red and white cables for audio in and the yellow cable for the video in.
Sylvania 6427TE... | Answered on Jan 12, 2014
Sylvania 6427TE 27" TV Logo
178 questions posted
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
help me find all 3 digit codes sylvania
  • Televison & Video
