20 Most Recent Sanyo DP26648 LCD TV Questions & Answers
How to access the menu on sanyo dp26648 without remote
You can't without the remote. to buy one go here www.remotes.com or try eBay.
11/29/2016 11:50:07 PM • Sanyo DP26648... • Answered on Nov 29, 2016
My volume has gone out all of a sudden, what can be done about it???
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
11/14/2014 4:31:17 PM • Sanyo DP26648... • Answered on Nov 14, 2014
Had a power outage and my sanyo DP26648 will not come on, it was on a surge bar, the green light comes on for about 4-5 sec and then goes off is there anything I can do to fix it
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
10/4/2014 5:20:35 PM • Sanyo DP26648... • Answered on Oct 04, 2014
How do I get this remote with Netflix capability
That model TV is not a smart TV meaning it will not be able to access Netflix by itself. You will need another piece of equipment such as a video game console (a Sony PS3 or PS4 for example) or a DVD player with the Netflix app. to run Netflix on your TV. The remote for that auxiliary equipment will be the one that operates Netflix. We bought a Sony Blu-ray player for under $70 that has the Netflix app plus many more. You also need internet access for this to work. A wireless setup works well.
7/6/2014 6:29:13 PM • Sanyo DP26648... • Answered on Jul 06, 2014
Unit turns off after 3 to 5 seconds
This does not sound like a capacitor problem.Bad capacitors usually cause the TV to have a SLOW startup, not so much to shut off after they are once started. Of course both are possible, but the former is a whole lot more common (based on my experience).Also, bad capacitors are usually easy to spot even with a naked eye. Just look at your power supply board and see if there are any that are bulging.Not seeing any is not a guarantee, but more often than not is sufficient to rule that out as a possibility.Finally, here are some repair and replacement alternatives for DP26648 power supply issues:http://www.coppelltvrepair.com/search?q=DP26648
5/8/2014 2:25:04 AM • Sanyo DP26648... • Answered on May 08, 2014
No signal???
yes when you swich off tv and you put it back on the nexst day the tv sets to pick up analog wich it is cnot set up for on your control there shoud be a white button press it on the second one on your list and it shoud be fine
4/7/2014 6:46:34 PM • Sanyo DP26648... • Answered on Apr 07, 2014
0answers
No sound
Be the first to answer 2/8/2014 3:46:49 AM • Sanyo DP26648... • Posted on Feb 08, 2014Be the first to answer
Sanyo tv
4/27/2013 11:47:59 PM • Sanyo DP26648... • Answered on Apr 27, 2013
2answers
What could cause a 27" Sanyo flat panel dp26648 to lose picture, but keep sound?
There are two reasons why your Sanyo DP26648 would has sound but no image and both are equally likely in our experience.First, you may have a problem in the section of the power board that supplies the backlight module (called inverter) with 24V.We've seen that several times and the problem is usually minimal - only electrolytic capacitors gone bad - and other times not so minimal.We have a repair service for that power board and we may have some boards available too...check out athttp://www.coppelltvrepair.com/search?Q=DP26648+&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
8/25/2012 5:48:09 PM • Sanyo DP26648... • Answered on Aug 25, 2012
How do I connect a playstation 3 to my sanyo tv DP26648
try it on another set first to see if game or the set is the issue.
6/17/2012 7:05:46 PM • Sanyo DP26648... • Answered on Jun 17, 2012
Sanyo DP26648 LCD TV Logo
48 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
unit turns stays 3 5 seconds shuts
  • Televison & Video
