20 Most Recent Sanyo DP50747 50 in. Plasma TV Questions & Answers
Model? If its only a week old take it back where you bought it, its under warranty
Sanyo DP50747 50... | Answered on Jan 18, 2018
The sound card of the tv need to be replaced. It is on its way out.
Sanyo DP50747 50... | Answered on May 23, 2017
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sanyo DP50747 50... | Answered on Apr 25, 2017
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sanyo DP50747 50... | Answered on Jun 13, 2016
Try to change the Inverter board (Buffer board).
Sanyo DP50747 50... | Answered on Mar 31, 2016
Definitely drivers, and may or may not be repairable. Here is what I understand. It depends on how the plasma panel in that set was made. Some panels have the X-drivers on a separate board. Others bond the drivers to the plastic ribbon connected to the panel. If it's a separate board, the board can be replaced. If it's bonded to the ribbon, it's virtually impossible to replace the defective chip.
Sanyo DP50747 50... | Answered on Feb 03, 2016
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Sanyo DP50747 50... | Answered on Jan 24, 2016
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check remote, alternate between manual and remote start ups to see if that helps
Sanyo DP50747 50... | Answered on Jan 15, 2016
Try a factory reset [hard reset] to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sanyo DP50747 50... | Answered on Jan 11, 2016
you need to get a converter that takes pal and converts it to ntsc.
Sanyo DP50747 50... | Answered on Dec 08, 2015
There may be no cable signal at the wall connection.
Sanyo DP50747 50... | Answered on Sep 01, 2015
Sanyo DP50747 50... | Answered on May 13, 2015
Sanyo DP50747 50 in. Plasma TV Logo
416 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
tv worked fine about year or
  • Televison & Video
