Microwave Ovens Logo
Posted on Jun 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the black/stainless steel m/v MV8999sb. Just today, when I used the any express cooking button, instead of cooking, it is acting like a kitchen timer. It is also flashing to icons on the top; one looks like a bowl with steam or something. can you help. I don't have a manual as I bought it used.
Level 3:
  • Emerson Master 6,688 Answers
  • Posted on Jun 06, 2011
Cindy  Wells
Emerson Master
Level 3:
Answers
6688
Questions
0
Helped
3533144
Points
21745
The two icons are normally present for any timed cooking in this microwave. If you are not getting the food to heat (since express cook is at 100% power), the magnetron, thepart that produces the microwaves, may be damaged. If your unit is out of warranty, it may be easier to replace it.
The part itself is fairly cheap: http://www.partstore.com/SearchResults.aspx?q=Magnetrons&cft=Microwaves+_gt_+Magentrons&cfilt=374&sort=salesrank&ctf=Parts&ctfn=Parts&ps=100&bf=731&bfn=Emerson . However, you need to avoid damaging the seals to avoid having the radiation leak. (It makes the microwave inefficient and can be dangerous to people and pets nearby.) Additional parts for microwaves are also available at partstore.com: http://www.partstore.com/Content/CategoryPages/Kitchen-Microwaves.aspx .
The manual for the MV8999sb is available here: http://kitchen.manualsonline.com/manuals/mfg/emerson/mw8999sb.html . Click the Get this Manual button. See page 13 of the PDF for the pictures appropriate to the Quick Cook option.
I hope this helps.
How do you turn the turntable on a frigidare microwave model fgmv155ctf on and off
Image Disclaimer
AUTHORIZED DEALER Frigidaire Gallery Series
FGMV155CTF
30 Inch Over the Range Microwave Convection Option Sensor Cooking SpaceWise® Rack
4.4 Average rating of
73 reviews
color: smudge proof stainless steel
Smudge Proof Black Stainless Steel FGMV155CTD
$569.00
Smudge Proof Stainless Steel FGMV155CTF
$519.00
product highlights
Optional Built-In Trim Kit Convection Sensor Cook quick specs
Dimensions
Width: 29 7/8 Inch
Depth: 15 7/16 Inch
Height: 16 13/32 Inch
Features
Capacity: 1.5 Cu. Ft.
Cooking Watts: 900
View more Frigidaire 4 Piece Kitchen Appliances Package
Get the bundle for just $3,44800View the Bundle Recommended Accessories Available Colors/Finishes Stainless Steel (FGMV155CTF) Black Stainless (FGMV155CTD)
Frigidaire GALLERY™ 1.5 Cu. Ft. 900W Over-the-Range Convection Microwave
Save
Model No: FGMV155CTF
Features:
  • 170/300 CFM 2-Speed Exhaust Fan
  • Convection Option & Sensor Cooking
  • Express-Select™ Controls
  • SpaceWise™ Convection Rack
  • Effortless Clean™ Interior
How to cook something for 16 minutes
if you have a time cook setting put in 16 and start
Kenmore 62463 / 721.62463201 Stainless Steel 1200 Watts Microwave. My daughter used it as a timer for reading and set it to cook for 30 minutes with nothing in it. It turns on but is loud and no longer...
You probably fried the magnetron(it actually makes the microwaves that do the cooking). I bet you will find the magnet is broken(from excessive heat). There should be a diagnostic guide sheet somewhere inside the housing(due to running production changes,this is a guide for the pros to test the power supply,magnetron,etc with an ohmmeter to determine which is defective.
2helpful
New microwave stopped working after 15 seconds
Possibly the fuse / breaker is tripped, usually all outlets in one room share same breaker. Check breakers (or fuses) or try outlet in differnt room. If the outlet has power, (plugin a lamp to check) and the microwave still does not work, take it back to store for replacement or refund.
1helpful
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
I need the specs (size, height, width etc) for the GE Spacemaker XL Model#JVM1631WB 004
Specs are:
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWave™ Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5 speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9 Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6 codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto & Time
Delay Start: Yes
Display On/Off: sub-pad w/ zero
Express Cook: Instant-on 1-6
Reminder (24 hr): Yes
Time Cook: I & II
Time Preference: Control Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire Oven Rack
Sound Volume Control: 4 levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless Steel
Door Color: Black/Stainless Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63 lb
Overall Depth: 15 5/8"
Overall Height: 16 3/16"
Overall Width: 29 7/8"
Cavity (W x H x D): 20 31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
I have owned a AMC5101AAW for about three and a half years. It has been a good microwave,perfect for my needs. The display went black and the buttons didn't work right after I boiled a cup of water for...
It sounds like it could be just a bad crimp connector supplying power to the whole system, which would have to be the fuse holder on the mains input panel.
Worth a look!
I have a new induction cook top. When using for the first time I found an F or P appeared next to the element I was using. I have bought stainless steel cookware specifically to use. The user manual...
Stainless steel (or Aluminium) cookware will not normally work with an Induction cooker: Induction cooker need cookware that have a certain amount of metal especially at the bottom of the pot or pan.
An easy way to check if the cookware is suitable is to use a small (fridge) magnet: if it stick to the pot/pan then it is very likely that the pot/pan is suitable for induction 'magnetic' cooking!
Hope my small hint is of assistance and if so, vote accordigly!
How to clean GE Advantium???
Get a stainless steel "brillo pad" at the grocery store.
When you get home ... put a microwave safe container with water inside it ... in the oven. do not heat for more than 2 minutes!!!!! The resultant steam will soften the gunk. Use the stainless steel cleaner pad gently to remove the goop.
I hope this helps you
a
Microwave caught on fire.
I agree! That is an extreme hazard. Possibly due to over voltage of the power supply or faulty relay systems. Emerson is usually a cheaper brand anyhow. I would get the money back instead of exchange.
Top Emerson Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
