20 Most Recent Emerson MW8102SS 1100 Watts Microwave Oven Questions & Answers
Replacement trays cost around $30.00. The cheapest I found was on Ebay for $28.00. By the time you pay for shipping you can almost buy a new appliance. Also take care that you find one for your model, you can't always tell by looking if it is going to fit.
Try your local Goodwill or other thrift store for a used one.
Good luck
Emerson MW8102SS... | Answered on Jun 24, 2019
Ok just figured this out! It is a problem with the alignment on the lower door switch. I took the cabinet off and lifted up on the door switch slightly and voila! It works. You could probably fix this without taking it apart, just lift up on the door ever so slightly. I hope this works for you.
Emerson MW8102SS... | Answered on Dec 30, 2017
It needs replaced right now is a good time to replace it there are a lot of retailers that have them on sale hope this helps Merry Christmas
Emerson MW8102SS... | Answered on Dec 09, 2017
Usually caused by food fragments burning and reaching flashpoint.
If the magnetron is still OK, a good clean and a new waveguide cover should fix it.
Emerson MW8102SS... | Answered on Apr 10, 2017
That piece is called the waveguide cover. Emerson calls it a spatter shield. Behind it is the hole where the microwaves enter the oven. Its job is to prevent food spatters from getting into the microwave source, and it's not a good idea to run the oven without it.
The cover is usually held in place by a plastic rivet that pulls out. I couldn't find the part number for the cover used in your model. But here is a link to a parts place that has several covers available:
http://www.a-1catalog.com/wavandstirco.html
If one of the covers shown looks like yours you can order it. Another possibility is to contact Emerson at 800-695-0098. This is the number they give to locate authorized servicers near you, and you might be able to order a replacement cover through them.
Hope this has helped. If so, please take a moment to rate the solution. Thanks for asking here!
Emerson MW8102SS... | Answered on Feb 26, 2016
open it up check the battery in microwave replace check fuse replace then put back together then you should be fine.
Emerson MW8102SS... | Answered on Mar 10, 2015
There is no reset button. You will need a control board.
Emerson MW8102SS... | Answered on Dec 14, 2014
I bought my emerson microwave 3 years ago model# mw8115ss from walmart and have had all the problems that everyone has talked about and I thought about throwing it away until I thought about one small detail, the FUSE. China uses junky glass fuses that burst instantly with a slight power outage, door slamming to hard, moving it around, and of course constant use like myself always heating up water for bottles. I took the back of the microwave off and walla!!! a blown fuse, but wait!!! dont buy another glass fuse!!! go to your local home depot and get the ceramic fuse for microwave ovens!!! they are $2.83 at my local home depot. I replaced the junky glass fuse with the ceramic one and it has worked perfectly for six months now.
DONT let someone tell you that you cant replace a glass fuse with a ceramic one because they are full of boloney. My microwave did all kinds of things, it wouldnt turn sometimes, it would come on by itself, it would beep for no reason, turn but not heat up, you name it I had the problem. When a fuse starts to go out it can make your appliances do some strange things, check the fuse and replace it with a CERAMIC one and I promise it should eliminate your problem.
Emerson MW8102SS... | Answered on Jun 19, 2014
You have blown the microwave internal fuse. If you are handy enough you can take the cover off and follow the power cord in the system. The fuse will be between the transformer and the power cord
YOU MUST DISCONNECT POWER CORD AS PART OF ELECTRICAL SAFETY WHILE WORKINGON ON THE SYSTEM!!
Emerson MW8102SS... | Answered on Apr 16, 2014
Emerson MW8102SS 1100 Watts Microwave Oven Logo
295 questions posted
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Microwave Ovens
Most Popular Question
reset emerson microwave
  • Microwave Ovens
