SOURCE: IR receiver on unit not working?
Sounds to me like the issue is the rx in the unit. It can be fixed with very little work if you can locate the part. Let me take a look and see if I can locate the part number for you. Although I have to say that Kenwwod can keep a tight lip on their parts lists.
It seems to be a general problem on Kenwood Receivers. Pls check this out http://www.moerk.org/kenwood/ or this http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/
regards sgershoj
SOURCE: power from the kenwood 9103D to the Kicker comp 15's is on n off
Most times I hear of people turning up the volume on a head unit and cutting off on the amp it tends to be wired to a speaker with the wrong impedance. I googled kicker comp and got tons of different models, not to mention almost all of them were 250 watt rms. That amp is 900 watt RMS at 2 ohms. If you only have 1 woofer, you can't possibly wire it wrong being all the subs I've seen in the results were 4 ohm. If you are using just one though, you should get a larger speaker, both 2 ohms and 1000 watt rms to prevent distortion. I'm afraid I can't answer your post without further information on the sub you are using.
SOURCE: Volume control for kenwood krv5580
I was able to get the volume control to work, but how do you get an amplifiter to hook up to it?
