20 Most Recent
Onkyo TX-SR304 Receiver Questions & Answers
What remote control code does the Onkyo TX-SR304 use?
1) Tap AUX2) Press & Hold Setup (1 then 2 blinks)3) Enter 30842 or 0842 (The remote should blink twice)4) Press & Hold Setup (1 then 2 blinks)5) Enter 994 (2 blinks)6) Tap Setup (1 blink)7) Enter "00051" (1 blink per number)8) Tap Power (not All On, just "power") (The remote should blink twice)9) Tap AUX10) Press & Hold Setup (1 then 2 blinks)11) Enter 30135 or 0135
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Remote wont work
you get better play back using an analog input like tape. the sound is true to form and better vocals and bass response.
New receiver....old CD, record and tape players
Most new recievers don't have a "phono" input. If your record player is an older kind without a built in preamp, you will need to purchase a Phono pre-amp (about $25) and then you can use any input you wish.
Receiver Shuts down at 45 level
I was having a similar problem and I found that the positive and negative speaker wires were touching on the speaker connections made in the receiver.
