I have the JBL MBB-218, the problem that I am having is when I power up the system all the lights are on on the display and all I am getting is static?????
JBLhttps://ca.jbl.com > warranty
Unless a different warranty period is stated in the Warranty Card provided with your JBL product, JBL warrants for a period of 1 year (5 years for any non- ...
JBL Charge 4 TroubleshootingiFixithttps://www.ifixit.com > Wiki > JBL_Charge_4_Troub...Make sure the charging light on the base of the device is blinking. If it is fully charged and still not turning on, the power button may be worn out or broken. ‎The Speaker Will Not Power... · ‎The Device Won't Connect to.....
There should be a short circuit inside its circuit board. You have to check the audio output circuit to get the fault, and to replace the damaged component/s. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Circuit diagrams of SMPS & power amplifier to many models of JBL sets are given.
The power supply consists of two parts: the AC cord with a two-prong connector on one end and a double barrel plastic connector; and the large rectangular power supply which has a dual prong receptor on the side and a long cable which plugs into the JBL unit.
In my case, I had plugged the double barrel plastic connector into the dual prong receptor backwards. Even though I was getting full power to the unit, this somehow caused the speakers to become inoperative.
Of course, I would offer a recommendation to JBL that their power supplies are made to be "dummy proof" so this does not happen to others as well.
What you'll actually need in order to get Sirius is a satellite specific receiver (the JBL SIR 2.5 Satellite Receiver). That should come with the antenna you need.
