20 Most Recent JBL On Stage Micro Portable Speaker Dock for Apple iPod - Black Questions & Answers
2answers
Will the jbl on stage micro charge the new ipod touch
I can tell you that I have the on stage micro, bought this past winter. And it does charge my iPhone 3G. Works great, I love it.
1/27/2013 3:38:34 PM • JBL On Stage... • Answered on Jan 27, 2013
2answers
Why cant I charge my 5th generation ipod on my
try pulling the ipod out of the dock while both are turned on or unpluggin and re-plugging the adapter... works for me
4/27/2012 8:04:27 AM • JBL On Stage... • Answered on Apr 27, 2012
0answers
How to connect pendrive usb to JBL ipod dock
Buy a universal USB cord which has many different connecting ends. Easily available in electronic shops.
Connect USB 2.0 to the pendrive and the other end to JBL IPOD dock
11/23/2009 8:31:41 AM • JBL On Stage... • Answered on Nov 23, 2009
JBL on stage II speaker doesn't work
If your 120v unit is not marked for use with 220-240v and you plugged it into such a socket (even once), you probably fried the AC adapter and will need to get a replacement.
9/26/2009 8:49:36 PM • JBL On Stage... • Answered on Sep 26, 2009
When plugged in, the ipod batteries go low immediately.
The JBL On Stage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adapter. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adapter. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried this on different versions of the iPod nano and this seems to work.
9/26/2009 8:40:49 PM • JBL On Stage... • Answered on Sep 26, 2009
JBL on stage micro will not charge my ipod any
The JBL Onstage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adaptor. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adaptor. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried it on the new 5th generation nano and this seems to work.
9/26/2009 8:34:25 PM • JBL On Stage... • Answered on Sep 26, 2009
No Sound from JBL On-Stage 400
The power supply consists of two parts: the AC cord with a two-prong connector on one end and a double barrel plastic connector; and the large rectangular power supply which has a dual prong receptor on the side and a long cable which plugs into the JBL unit.
In my case, I had plugged the double barrel plastic connector into the dual prong receptor backwards. Even though I was getting full power to the unit, this somehow caused the speakers to become inoperative.
Of course, I would offer a recommendation to JBL that their power supplies are made to be "dummy proof" so this does not happen to others as well.
7/29/2009 3:43:18 PM • JBL On Stage... • Answered on Jul 29, 2009
JBL On Stage for iPod
Hi, I guess that's just a problem that can't be solved by yourself, you'll probably have to bring it back.
I have thesame speakerset, but I don't know how you can remove that thing where the ipod stands in. That plastic thing that comes in a lot of different sizes. I hope that you can help me with removing it and putting an other one in.
2/9/2009 12:27:56 AM • JBL On Stage... • Answered on Feb 09, 2009
Want to hook up an IPOD to professional sound equipment.
Shouldn't really need any equipment. You can use a RCA to 1/4" phono adapters.
One for the right and one for left.
If you mixing console already has RCA input then you don't need an adapter.
Make sure you set the volume level on your ipod around 1/4 to 1/2 way up and then turn up the channels your piped into. If the faders don't give you enough gain (volume) then turn up the ipod I bit more. Just watch your imput signal and make sure your not clipping or the sound will be distorded.
Should be straight forward.
1/29/2009 9:32:14 PM • JBL On Stage... • Answered on Jan 29, 2009
Song will skip
Hi maybe you have unsupported format to your unit! or you need to look your setting in playmode...
Thanks!
6/30/2008 12:58:50 AM • JBL On Stage... • Answered on Jun 30, 2008
JBL prx612m humming and cracking sound what can be the solution
The causes can be poor connection in the signal input lead, could be the mixer you use, could be a speaker failurs, could be an amplifier failure.
1/21/2024 10:47:01 AM • JBL Audio... • Answered on Jan 21, 2024
My JBL PRX 512m humming and rattling is the problem with the amp side or pre amp.
Could be either or both. You will have to fault find to get an answer.
1/20/2024 7:02:45 AM • JBL Audio... • Answered on Jan 20, 2024
How to open jbl on stage 200id?
To open the JBL On Stage 200iD, you need to follow these steps: Remove the power adapter from the back of the device. Turn the device over so that the bottom is facing up. Locate the six rubber pads on the bottom of the device and remove them using a plastic opening tool. Remove the six 1cm T-10 torx screws found under the rubber pads using a T-10 Torx screwdriver. Open the device along its seam. For more information, please refer to the JBL ON STAGE 200ID USER MANUAL. https://www.manualslib.com/manual/788652/Jbl-On-Stage-200id.html
10/27/2023 9:59:32 PM • JBL Audio... • Answered on Oct 27, 2023
JBL On Stage Micro Portable Speaker Dock for Apple iPod - Black Logo
Popular Tags
27 questions posted
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JBL Audio Players & Recorders
Most Popular Question
get adaptor
  • Audio Players & Recorders
